isolcpus Setting in Buster
- Project_Hopeless
- Thank you received: 10
30 Dec 2020 01:28 #193475
by Project_Hopeless
isolcpus Setting in Buster was created by Project_Hopeless
I'm following the guide for GRUB2 isolcpus setup.
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is...rameter_And_GRUB2i'm using
For quad core it instructs RTAI_OPTS="isolcpus=1,2,3"
For dual core it instructs RTAI_OPTS="isolcpus=1"
In some of the latency testing posts I see quad cores set to RTAI_OPTS="isolcpus=2,3" This is opposite the wiki that the last core should be used. Just wondering why?
Lastly, I'm running a Mesa 7i96e card. What would be the recommended isolcpus setting?
- Thank you received: 5330
30 Dec 2020 02:52 #193480
Replied by PCW on topic isolcpus Setting in Buster
Unless you have an actual latency issue I would not use any isolcpus
options at all
options at all
- Project_Hopeless
30 Dec 2020 16:06 - 30 Dec 2020 16:07 #193556
by Project_Hopeless
Under Mint I had issues, more of a intermittent spike. Being a hobby machine I just doubled the Servo Period and that seemed to take care of it.
Now that I'm seeing better latency numbers under Buster I was hoping to run the default servo period.
With Buster, all 4 cores, latency test jitter Servo=15K Base=14K. Using isolcpus I'm seeing lower numbers yet again. I understood these number to be good.
However with the new scrip test...
forum.linuxcnc.org/18-computer/39371-res...ith-linuxcnc?start=0
the results don't seem as good comparative to other peoples' results. Am I making to much of it? Whats the potential down side to running isolcpus?
Replied by Project_Hopeless on topic isolcpus Setting in Buster
options at all
Last edit: 30 Dec 2020 16:07 by Project_Hopeless.
- Thank you received: 7488
30 Dec 2020 17:24 #193564
Replied by tommylight on topic isolcpus Setting in Buster
Do not worry to much about latency, LinuxCNC will inform when it is not OK.
Get the machine working, if you get latency warnings, raise the base thread/period a bit and test again.
That is if using the Parallel port.
- Project_Hopeless
30 Dec 2020 17:59 #193567
by Project_Hopeless
No parallel port, I'm running a Mesa 7i96e ethernet card.Do not worry to much about latency, LinuxCNC will inform when it is not OK.
30 Dec 2020 18:44 #193574
That makes latency even less relevant, up to the point of loosing connection to the board.
No parallel port, I'm running a Mesa 7i96e ethernet card.[/quote]That is if using the Parallel port.
- Project_Hopeless
02 Jan 2021 16:59 #193856
by Project_Hopeless
The last time I had a latency issue I simply doubled the Servo Period. If I raise the default Servo Period are there specific increments or is any value valid. For example will some value or multiplier lead to a rounding error in the math or a harmonic in the response?Do not worry to much about latency, LinuxCNC will inform when it is not OK.
02 Jan 2021 19:08 #193875
Not sure really, but i do test and use some at 500K and sometimes 2mill on two of the laptops.
Otherwise i would think that any divisible number would not cause issues.
- Thank you received: 4150
03 Jan 2021 02:51 #193920
No there is no need to worry. In a hal component there is a variable called period and also fperiod which report the servo period in nanoseconds and seconds. So any component requiring timing info "SHOULD" use these, not blindly count periods...
Replied by rodw on topic isolcpus Setting in Buster
Time to create page: 0.105 seconds
