LinuxCNC Debian Buster with X11VNC
- Rilke1999
07 Jan 2021 20:01 - 07 Jan 2021 20:24 #194404
by Rilke1999
LinuxCNC Debian Buster with X11VNC was created by Rilke1999
I used to mirror the screen of my LinuxCNC workstation running Jessie with X11VNC to my main computer. This worked great and I could use both maschine in parallel without starting a new X11 session. It was very performant and worked great.
I now have setup a new machine with 2.8.1 and Debian Buster, but the X11VNC package (an extremely old .9.1.3 does not seem to work any more, creating extreme load for X11 process.
The .9.1.6 supllied with the latest debian 11 "bullseye" works with a testing system great, however there is no LinuxCNC version available for this.
Any other solution to mirror screen, keyboard and mouse ? Import would be that both session run in parallel.
Last edit: 07 Jan 2021 20:24 by Rilke1999.
- Mike_Eitel
- Thank you received: 183
07 Jan 2021 21:10 #194417
by Mike_Eitel
Replied by Mike_Eitel on topic LinuxCNC Debian Buster with X11VNC
Xrdp
- Thank you received: 7488
07 Jan 2021 23:27 #194431
Replied by tommylight on topic LinuxCNC Debian Buster with X11VNC
VNC, or TightVNC, or any of the other remote desktop apps.
X11 is getting dropped completely and Wayland is replacing it,.
- Rilke1999
08 Jan 2021 11:32 #194478
by Rilke1999
Replied by Rilke1999 on topic LinuxCNC Debian Buster with X11VNC
Is any of this alternative able to mirror so the session can beseen and inputed on more than one device? (and is not as evil as teamviewer
- Mike_Eitel
08 Jan 2021 18:05 #194524
by Mike_Eitel
Not xrdp
This opens your own User.
10 Jan 2021 18:39 #194749
You could try installing the LinuxCNC kernel and application .debs on Bullseye. There is a pretty good chance it will work.
If not, there is probably a preempt-rt kernel available for Bullseye, and then you can try the LinuxCNC .debs again, and if that doesn't work, build from source.
Replied by andypugh on topic LinuxCNC Debian Buster with X11VNC
- Rilke1999
15 Jan 2021 09:25 #195417
by Rilke1999
Sorry for the late reply, I was busy compiling LinuxCNC on bullseye and this took a while to figure out the necessary dependency, Seems to work but needs to be tested with my machine which is currently in rebuild status.
Time to create page: 0.093 seconds
