Auto Login : Buster
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
16 Jan 2021 19:13 #195561 by Project_Hopeless
Auto Login : Buster was created by Project_Hopeless
I have the LinuxCNC Buster ISO loaded. I followed a Linux forum on how to enable/disable auto login. I needed to edit some lines in the following file.
sudo nano /etc/lightdm/lightdm.conf
However I get a directory does not exist. So do i create the directory and file from scratch? Our is there another way?
16 Jan 2021 20:30 #195573 by robertspark
Replied by robertspark on topic Auto Login : Buster
This may help (sorry I did it earlier in the week) via the terminal
vitux.com/how-to-enable-disable-automatic-login-in-debian-10/
  • Project_Hopeless
  • Elite Member
  • Elite Member
16 Jan 2021 23:23 #195590 by Project_Hopeless
Replied by Project_Hopeless on topic Auto Login : Buster
That instruction set did not work with the LinuxCNC Buster ISO.
I did eventually find a solution here;
steemit.com/software/@kskarthik/how-to-e...uto-login-in-lightdm
The file to edit was stored in a different directory.
sudo nano /usr/share/lightdm/lightdm.conf.d/01_debian.conf
The following user(s) said Thank You: joekline9, hoffb77
Time to create page: 0.311 seconds
