LinuxCNC 2.8 blank login screen after successful install
19 Jan 2021 20:02 - 19 Jan 2021 20:03 #195914 by anrstone
Hi
I'm new to LinuxCNC and I'm having an odd issue with the install. I have tried the latest 2.8 release both using the graphics mode and text mode install and everything works fine until I reboot. At which point Linux appears to boot normally and then at the very last stage where I assume the login screen would show the monitor warns of a connection been dropped and the screen is blank. I have tried the PC using a straight copy of Debian and it drives the display without issue.
Any ideas how to fix this or even diagnose it?
Last edit: 19 Jan 2021 20:03 by anrstone.
  • Moderator
  • Moderator
19 Jan 2021 21:23 #195920 by tommylight
Did you check the md5sum of the downloaded ISO?
linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html
Section 1.3 Verify the image.
20 Jan 2021 08:49 #195977 by anrstone
Yes the MD5 was all good
  • Moderator
  • Moderator
20 Jan 2021 11:19 #195985 by tommylight
Am on phone in car so not much i can help, but do a search for
Grub nomodeset
See if that helps.
20 Jan 2021 16:38 - 20 Jan 2021 18:13 #196005 by anrstone
That got me to the login screen - thanks
After trying the 2.8 install I have reverted to the 2.7 as the jitter was off the chart (100000+) with 2.8 (8000 with 2.7) and the display simply wouldn't render to any sort of sensible resolution. I'm guessing there are issues with the display hardware which is Nvidia using the 2.8 install but unfortunately I don't have time to dig in now. I don't fully understand why the jitter would be that bad but if anyone has ideas I can spend some time may be at the weekend trying again.
Last edit: 20 Jan 2021 18:13 by anrstone.
22 Jan 2021 01:18 #196171 by andypugh
You should be able to upgrade your 2.7 install to LinuxCNC 2.8.1 _without_ changing the OS or kernel.
The actual LinuxCNC version should have no affect on latency.
23 Jan 2021 11:06 #196324 by anrstone
Let me try that thanks
Time to create page: 0.265 seconds
