LinuxCNC install from USB
5 years 9 months ago #197163 by robertspark
Could it be the file size limit on the USB
FAT16 / FAT32 / 2gb / 4gb limit (I use old usb sticks and have not had a problem, the one I tend to use the most is probably a 4gb stick and I've reinstalled LinuxCNC from iso a number of times whilst I dabble and try to figure out how to break it).
5 years 9 months ago #197165 by Swag
Replied by Swag on topic LinuxCNC install from USB
I have to assume it is something with Debian 10 as it worked fine when installing on the same system with the Debian 9 - LCNC2.7 ISO.
The following user(s) said Thank You: joekline9
5 years 9 months ago #197182 by pdxalz
Replied by pdxalz on topic LinuxCNC install from USB
I found that the utility I used to make the USB drive made a difference. I first used the Rufus running Windows 10. Using the recommended ISO Image mode I had the detect problem, but ejecting the usb and reinstalling allowed it to work. In Rufus, if I selected DD image mode, it worked fine with no problems. Also, if I used a linux system and used the "dd" method it also worked fine.
5 years 9 months ago #197264 by andypugh
Replied by andypugh on topic LinuxCNC install from USB
Swag wrote: I have to assume it is something with Debian 10 as it worked fine when installing on the same system with the Debian 9 - LCNC2.7 ISO.
Yes, this is a problem with the Debian 10 installer.
The workaround is to unplug and re-plug the USB stick at the point that it complains about not finding the CDROM...
4 years 3 months ago #247811 by Nigel Pearson
I had the same problem. Installing from a microSD in a card reader. No combination of unplugging/re-inserting helped.
So, I put the ISO on a regular USB memory thingy – a Lexar 4GB. It worked fine.
When I was dd-ing the ISO on, I noticed that it was close to 2GB, maybe slightly over? My microSD was 2GB :-(
It booted live image OK, but maybe the install uses different parts of the ISO?
4 years 3 months ago #247845 by tommylight
If the image is bigger than the card/usb, DD will just report it at the end when it has no more space to write to, only if verbose mode is used. The resulting card/usb will not be usable in almost all cases.
Time to create page: 0.365 seconds
