LinuxCNC install from USB
- ogrepsu
- Thank you received: 3
20 Jan 2021 23:50 #196037
by ogrepsu
LinuxCNC install from USB was created by ogrepsu
I am trying to install the LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT ISO from USB. When it goes to install, it tries to detect and mount the cd-rom. I installed the LinuxCNC 2.8.0 Debian 7 Wheezy RTAI without this problem but want to use the latest version. Anyone else run into this issue and how do you overcome it?
- ogrepsu
21 Jan 2021 00:02 #196038
by ogrepsu
Replied by ogrepsu on topic LinuxCNC install from USB
NM figured it out. If you pull out the USB and mount it again then search for DVD it finds it. Odd install.
- Thank you received: 7487
21 Jan 2021 00:07 #196039
Sorry for the late reply.
Replied by tommylight on topic LinuxCNC install from USB
That seems to be the only solution so far, although i did install it several times and had no such issues a lot of members here reported that same issue.NM figured it out. If you pull out the USB and mount it again then search for DVD it finds it. Odd install.
- Swag
30 Jan 2021 13:45 #197157
by Swag
Replied by Swag on topic LinuxCNC install from USB
For whatever reason, I couldn't get it to install from USB at all (though I had previously installed 2.7 using USB). I ended up using a CDROM drive via USB. (Motherboard is a J3455B-ITX). Now reinstalling again after the system suddenly stopped booting to the GUI <sigh>.
- robertspark
- Thank you received: 216
30 Jan 2021 14:20 #197160
by robertspark
Replied by robertspark on topic LinuxCNC install from USB
go into the bios (f2 / F10 / delete)
change the boot order to usb first
- Swag
30 Jan 2021 16:32 #197162
by Swag
I don't think that would have helped. It will boot from USB, but after starting the graphical installer from USB it can no longer find the install files from the USB.
Anyway, installing from CD worked.
- robertspark
30 Jan 2021 16:40 #197163
by robertspark
Could it be the file size limit on the USB
FAT16 / FAT32 / 2gb / 4gb limit (I use old usb sticks and have not had a problem, the one I tend to use the most is probably a 4gb stick and I've reinstalled LinuxCNC from iso a number of times whilst I dabble and try to figure out how to break it).
- Swag
30 Jan 2021 16:51 #197165
by Swag
I have to assume it is something with Debian 10 as it worked fine when installing on the same system with the Debian 9 - LCNC2.7 ISO.
The following user(s) said Thank You: joekline9
- pdxalz
30 Jan 2021 23:04 #197182
by pdxalz
Replied by pdxalz on topic LinuxCNC install from USB
I found that the utility I used to make the USB drive made a difference. I first used the Rufus running Windows 10. Using the recommended ISO Image mode I had the detect problem, but ejecting the usb and reinstalling allowed it to work. In Rufus, if I selected DD image mode, it worked fine with no problems. Also, if I used a linux system and used the "dd" method it also worked fine.
01 Feb 2021 00:54 #197264
Yes, this is a problem with the Debian 10 installer.
The workaround is to unplug and re-plug the USB stick at the point that it complains about not finding the CDROM...
Replied by andypugh on topic LinuxCNC install from USB
Time to create page: 0.263 seconds
