No USB port work after install preempt rt on Pi 4
02 Mar 2021 09:03 - 02 Mar 2021 09:05 #200766 by thang
I try install lcnc on Pi 4 by follow this tutorial:
gnipsel.com/linuxcnc/uspace/rpi4-rt.html
All steps pass but when test result is bad:
+ All my usb ports dont work, lsusb only return:
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I had to use vnc for controlling
+ Latency-test give bad result and unstable for running servo thread
Does anyone have same problem, I'm using PI 4(4gb) vers 1.1 rev
Last edit: 02 Mar 2021 09:05 by thang.
02 Mar 2021 23:06 #200847 by andypugh
Try the "official" LinuxCNC Pi SD card image:
linuxcnc.org/docs/2.8/html/getting-start...tml#_normal_download
The following user(s) said Thank You: thang
05 Mar 2021 02:13 #201074 by thang
USB ports worked now with this image.
I also solve latency issue, it's because my bad power addapter, i just replace it and everything is fine now
Time to create page: 0.235 seconds
