linuxcnc-dev missing on 2.8-rt
12 Mar 2021 07:10 #201956 by uvos
linuxcnc-dev missing on 2.8-rt was created by uvos
Starting with plain debian buster i added:
deb http://linuxcnc.org/ buster base 2.8-rt
to the apt sources.
installing the RTAI kernel and the linuxcnc packge worked just fine. however the linuxcnc-dev package is simply missing and not in the repo at all. I need this package to compile some custom hal modules. where can i get the package?
  • Moderator
  • Moderator
12 Mar 2021 08:50 #201973 by tommylight
Replied by tommylight on topic linuxcnc-dev missing on 2.8-rt
sudo apt-get install linuxcnc-uspace-dev
12 Mar 2021 09:02 #201975 by uvos
Replied by uvos on topic linuxcnc-dev missing on 2.8-rt
no that wont work im on the buster "2.8-rt" repo see here linuxcnc.org/docs/2.8/html/getting-start...#cha:Installing-RTAI. That is the rtai version. linuxcnc-uspace-dev is in the 2.8-rtpreempt repo and applies only to the preemptrt version of linuxcnc.
  • Moderator
  • Moderator
12 Mar 2021 09:12 #201979 by tommylight
sudo apt-get install linuxcnc-dev
does that work?
Just had a look and i can not find RTAI version where the RT versions are.
12 Mar 2021 09:17 #201983 by uvos
No the repo dose not contain this package. this is all the packages the repo contains:
$ cat /var/lib/apt/lists/linuxcnc.org_dists_buster_2.8-rt_binary-amd64_Packages | grep Package
Package: linuxcnc-doc-cn
Package: linuxcnc-doc-en
Package: linuxcnc-doc-es
Package: linuxcnc-doc-fr
Package: linuxcnc
Package: linuxcnc
12 Mar 2021 09:20 #201984 by uvos
the duplicate linuxcnc entry is simply Version: 1:2.8.0 and Version: 1:2.8.1
12 Mar 2021 18:12 #202036 by andypugh
Replied by andypugh on topic linuxcnc-dev missing on 2.8-rt
You are right. That's a bit of an oversight.
I am building the package for 2.8.1 now
12 Mar 2021 18:45 #202038 by andypugh
OK, it should be available now.
