LinuxCNC at RPI4 with using IO Pins only ?
5 years 7 months ago #203968 by PCW
Yes, the TMC5160 can do this and probably others
Also the ST Micro PowerStep01
2 years 9 months ago #290919 by rufino
Is it possible to provide a tutorial for configuring the Raspberry Pi using GPIO with LinuxCNC?
2 years 9 months ago #290933 by rodw
Try  linuxcnc.org/docs/stable/html/drivers/hal_gpio.html
7 months 3 weeks ago #344095 by masawee
not is problem rpi use 3,3V and then use shift level converter module, cost 1-4 $ about and convert this gpio 3,3V to 5V out, then this 5V can connect wire to stepper motor drivers ETC, DM556.
7 months 3 weeks ago #344096 by masawee
arduino shield can use only toy motors, less than 2A motors can use, not have cnc machine motors too small, normal cnc used nema 23 470 OZ 3Nm motor 3-6Ampere current minimum cnc motors. and not need BOB card use big stepper motor drivers etc, DM556 drivers,
Time to create page: 0.069 seconds
