21:9 display
10 Apr 2021 08:35 #205513 by CaspianCmonster
21:9 display was created by CaspianCmonster
Hi I have setup my linuxcnc computer with a KVM switch so I can control it from my normal computer at my desk. That works fine but I happen to use a wide monitor (2560 x 1080) and I have tried a few remedies from line searches without success. I did manage to kill the gui and had to remember my command line so I could go remove the 10-monitor file I had created.
I can use it in the default 1920x1080 but that means everything is stretched 25% in the width which is kind of annoying :)
This is the standard iso install with Debian
Any ideas?
Luke
10 Apr 2021 16:15 #205533 by arvidb
Replied by arvidb on topic 21:9 display
Hmm, I assumed it would default to the native resolution of the monitor.
What graphics card do you have?
What does 'xrandr' say (when run in the terminal)?
  • Moderator
  • Moderator
10 Apr 2021 20:00 #205552 by tommylight
Replied by tommylight on topic 21:9 display
Did you test it without the KVM ?
10 Apr 2021 22:13 #205579 by andypugh
Replied by andypugh on topic 21:9 display
Aye, 'tis possible that the KVM is not passing the detection pins. Or is not passing them when the system needs them.
11 Apr 2021 09:36 - 11 Apr 2021 10:27 #205621 by CaspianCmonster
Replied by CaspianCmonster on topic 21:9 display
thanks for the replies, it is the same problem with or without the KVM switch (and the KVM switch works fine with the other two computers) I had used the Linuxcnc box with a different (normal size) monitor before but I am trying to save space in the workshop.
I just have to figure out how to add the 2560 x 1080 display size, it doesn't show it in xrandr
here are the top few lines from that:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 4096 x 4096
VGA-1 disconnected (normal left inverted right x axis y axis)
DVI-D-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
1920x1080 59.97 59.96* 60.00 50.00 59.94 59.93
The computer is a little single board atom
graphics is listed as:
Intel Atom Processor D2xxx/N2xxx Integrated Graphics
Last edit: 11 Apr 2021 10:27 by CaspianCmonster.
11 Apr 2021 10:30 #205623 by arvidb
This forum thread might give a clue: forums.debian.net/viewtopic.php?t=121795
Is yours a GMA 500 too?
11 Apr 2021 16:26 #205652 by andypugh
If all else fails, try the old-fashioned hand edit to xorg.conf. (You might have to create the file)
askubuntu.com/questions/74808/how-do-i-f...solution-of-1024x768
If you are using the LinuxCNC ISO then you won't have gedit, but gksudo geany... should work.
Time to create page: 0.301 seconds
