Upgrading 2.8 -> 2.9 on Mint 19.3
- txtrone
- Thank you received: 106
17 Apr 2021 18:21 #206202
by txtrone
Upgrading 2.8 -> 2.9 on Mint 19.3 was created by txtrone
I am currently running 2.8 on Mint 19.3, this was all installed from an ISO that BeagleBrainz generously created for the community. What is the 'cleanest' way to upgrade from 2.8 to 2.9 from this configuration? thx
- Thank you received: 7488
17 Apr 2021 19:37 #206211
Replied by tommylight on topic Upgrading 2.8 -> 2.9 on Mint 19.3
buildbot.linuxcnc.org
has all the info, disable existing repo, add the master repo, do an update and a distro-upgrade = done.
The following user(s) said Thank You: txtrone
- txtrone
17 Apr 2021 19:45 #206215
by txtrone
Wow, that simple. Not sure what time you knock off, it's 9:45pm your time I think. I will try this right now.
Mint 19.3 = Debian Stretch right?
Replied by txtrone on topic Upgrading 2.8 -> 2.9 on Mint 19.3
17 Apr 2021 19:46 #206216
Mostly up till 3AM.
Yes and yes.Not sure what time you knock off, it's 9:45pm your time I think. I will try this right now.
Mostly up till 3AM.
- txtrone
17 Apr 2021 20:29 #206224
by txtrone
heh... that almost puts you in my timezone.
I am uninstalling packages. Does the glade3 need to go?
Are you on IRC?
Mostly up till 3AM.
Are you on IRC?
- txtrone
17 Apr 2021 21:01 #206227
by txtrone
Yes and yes
Ok. got 2.9 installed and fired up Axis using my existing launcher and it worked. That was almost *to easy* ...
I did uninstall Glade3 to be on the safe side, since it popped up in synaptic when I searched 'linuxcnc'.
Since I had my base machine setup in 2.8 ... am I good to go with installing QtPlasmac? I was expecting more of a fight.
17 Apr 2021 22:07 #206234
You should run Phill's script to install some stuff if you already have not done that, otherwise attack on all fronts !
- txtrone
18 Apr 2021 00:04 #206242
by txtrone
I got Qt loaded up, but I cannot get my tandem X axis to home.
- txtrone
18 Apr 2021 00:07 #206243
by txtrone
In HAL watch I can see that joint 0 homes, but joint 1 is not.
18 Apr 2021 09:44 #206283
Copy the joint/axis stuff from the old config ini file to the new one.
Do make a copy though, just in case.
Time to create page: 0.116 seconds
