Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
- Bari
- Thank you received: 234
19 May 2021 06:53 #209448
by Bari
Replied by Bari on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
Please post your dmesg after running the test suite but before rebooting.
It looks like you built it properly.
- Arthur_L
19 May 2021 07:02 #209449
by Arthur_L
Replied by Arthur_L on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
Sorry i had reboot..... I Sorry ...
if you want to look the mesg. i can compile RTAI again.
- Bari
19 May 2021 07:06 #209450
by Bari
Post your dmesg after running the test suite but before rebooting.
You don't have to recompile.
I will not likely look at it for 12+ hours from now.
- Arthur_L
19 May 2021 07:07 - 11 Jan 2022 03:18 #209451
by Arthur_L
xxx@xxx:/usr/realtime/testsuite$ sudo ./run
[sudo] password for bodor:
.runinfo is /usr/realtime/testsuite/.runinfo
No RTAI modules loaded.
Running insmod on /usr/realtime/testsuite/.runinfo...
CANNOT FIND MAILBOX
Cleaning up...
RTAI successfully unloaded.
Removing /tmp/runinfo...
Done.
CANNOT FIND MAILBOX
Cleaning up...
Done.
Last edit: 11 Jan 2022 03:18 by Arthur_L.
- Bari
19 May 2021 07:10 #209452
by Bari
Run: $ dmesg
It will likely be a big text file that you can add as an attachment to the post here.
Run: $ dmesg
- Arthur_L
19 May 2021 07:21 - 11 Jan 2022 03:18 #209453
by Arthur_L
dmesg
[ 0.000000] microcode: microcode updated early to revision 0x28, date = 2019-11-12
[ 0.000000] Linux version 4.19.152-rtai-amd64 (root@xxx) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.12)) #1 Wed May 19 11:14:24 CST 2021
- Arthur_L
19 May 2021 07:34 #209454
by Arthur_L
dmesg
- Arthur_L
19 May 2021 07:41 #209456
by Arthur_L
Sorry...dmesg file
- Arthur_L
19 May 2021 08:19 - 11 Jan 2022 03:19 #209457
by Arthur_L
I feel i'm about to give up
When I compile linuxcnc, I encountered a problem
1 ./configure
checking for g++... g++
checking whether the C++ compiler works... yes
checking for C++ compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
2 make // error:
LD [M] /home/xxx/Downloads/linuxcnc-2.8.1/src/mesa_uart.o
CC [M] /home/xxx/Downloads/linuxcnc-2.8.1/src/objects/hal/drivers/pcl720.o
scripts/Makefile.build:303: recipe for target '/home/xxx/Downloads/linuxcnc-2.8.1/src/objects/hal/drivers/pcl720.o' failed
Makefile:1550: recipe for target '_module_/home/xxx/Downloads/linuxcnc-2.8.1/src' failed
make[1]: Leaving directory '/usr/src/linux-headers-4.19.152-rtai-amd64'
/home/xxx/Downloads/linuxcnc-2.8.1/src/objects/hal/drivers/pcl720.c:172:25: error: expected ‘)’ before ‘->’ token
#define out (__comp_inst->out)
./include/linux/logic_pio.h:32:9: note: in expansion of macro ‘out’
void (*out)(void *hostdata, unsigned long addr, u32 val,
make[2]: *** [/home/xxx/Downloads/linuxcnc-2.8.1/src/objects/hal/drivers/pcl720.o] Error 1
make[1]: *** [_module_/home/xxx/Downloads/linuxcnc-2.8.1/src] Error 2
Makefile:465: recipe for target 'modules' failed
make: *** [modules] Error 2
1 ./configure
2 make // error:
Last edit: 11 Jan 2022 03:19 by Arthur_L.
- BeagleBrainz
- Visitor
19 May 2021 09:09 #209460
by BeagleBrainz
Replied by BeagleBrainz on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
I noticed you're using Ubuntu 16.04, you may not be able to use the prepackaged debs.
Are you intending to add a parallel port card to your machine ?
How are you intending to control your cnc machine ?
Time to create page: 0.205 seconds
