Testing Linuxcnc code on a loptop
- Elco
- Thank you received: 3
20 May 2021 12:25 - 20 May 2021 12:46 #209643
by Elco
Testing Linuxcnc G-code on a loptop was created by Elco
I would like to develop and test Linuxcnc G-code routines on my laptop, which runs Ubuntu 20.4 with a 5.8 kernel. I use dedicated hardware to run my mill, hence I am just looking for a LinuxCNC simulator. Browsing I found the 'LinuxCNC Pure Simulator' page, but I assume that is obsolete as in only refers to Ubuntu 12 and earlier. The topic 'Linux Mint 20 quick and nearly easy install' in the forum seems to mainly deal with the real time kernel issues.
I look for a solution to use spare time on travel to work on G-code. Is there a .deb package that I could install that does not require dealing with major dependency issues, or - even better - a subset that only has AXIS and the G-code interpreter? (Alternatively, I could take a Raspberry Pi along of course).
Thanks, Robert
Thanks, Robert
Last edit: 20 May 2021 12:46 by Elco. Reason: change 'code' in 'G-code'
- bevins
- Thank you received: 338
20 May 2021 12:34 #209644
by bevins
Replied by bevins on topic Testing Linuxcnc code on a loptop
I dont think you need a RT kernel to run the simulator. Install linuxcnc and run the simulator.
- BigJohnT
- Thank you received: 994
21 May 2021 01:49 #209718
by BigJohnT
Replied by BigJohnT on topic Testing Linuxcnc code on a loptop
Any stock kernel will work with a simulator.
linuxcnc.org/docs/2.8/html/getting-start...nate_install_methods
JT
JT
Time to create page: 0.083 seconds
