help needed installing linuxcnc as a simulator on my debian buster laptop
5 years 4 months ago #211598 by RDA
I also tried this before without success, sorry for not posting the result previously.
Error in startup script: bad pad value "3m": must be positive screen distance while executing "pack $w.msg -in $w.top -side right -expand 1 -fill both -padx 3m -pady 3m" (procedure "tk_dialog" line 65) invoked from within "tk_dialog .d [msgcat::mc "Copy Configuration?"] [msgcat::mc "Would you like to copy the %s configuration to your home directory so you can customize i..." (procedure "prompt_copy" line 3) invoked from within "prompt_copy $::inifile" invoked from within "if [ok_to_copy_config $::inifile] { set copied_inifile [prompt_copy $::inifile] if {$copied_inifile == ""} { c..." ("while" body line 6) invoked from within "while {1} { focus $::tree vwait ::choice if { $::choice == "OK" } { if [ok_to_copy_config $::inifile] { set copied_in..." (file "/usr/lib/tcltk/linuxcnc/bin/pickconfig.tcl" line 875)
I assume its about some screen size setting but I dont know where to even begin :|
5 years 4 months ago #211819 by andypugh
That's really odd, and a bit frustrating. What is crashing is actually the little dialog box which asks if you want to make a copy of the config.
There is an answer here: askubuntu.com/questions/1046620/a-git-gu...use-of-bad-pad-value
  • BeagleBrainz
  • New Member
  • New Member
5 years 4 months ago #211833 by BeagleBrainz
Great find Andy
5 years 4 months ago #212905 by ytiuqibu
I tried following tommylight's code to install a uspace version on Linux Mint 19.3 but failed with the errors shown in the attached text file
Where do I go from here
I couldn't paste the text as apparently it contains too many links to post directly
Cheers
Paul
5 years 4 months ago #212918 by tommylight
Yup bumped into the same issue today, the keyserver is ignoring us! :)
Saw a few days back PhillC posted about other valid keyservers but i could not find it.
In the meantime go to:
Buildbot.linuxcnc.org/dists
And find Stretch, Master OR 2.8, then amd64 and download the latest build of linuxcnc-userspace, then double click on it and follow the gdebi installation.
5 years 4 months ago #212936 by phillc54
tommylight wrote: Yup bumped into the same issue today, the keyserver is ignoring us! :)
forum.linuxcnc.org/38-general-linuxcnc-q...-05?start=280#212635
Time to create page: 0.195 seconds
