Run EMC on Different OS?
21 Sep 2010 23:05 #4277
by rexhunt
Run EMC on Different OS? was created by rexhunt
Is it possible to install EMC2.0 onto a different distro? I am thinking something like DSL
22 Sep 2010 05:54 - 22 Sep 2010 05:55 #4278
by ulda
Replied by ulda on topic Re:Run EMC on Different OS?
DSL= damm small linux?
In Theory It is possible to run emc on any linux distro.
I for example use gentoo amd64, gentoo x86 and ubuntu.
You have to configure and install
- a kernel with rtai extension (adeos patch),
- rtai
- emc.
It is not possible to run emc on anything other than a linux kernel.
- rtai
- emc.
Last edit: 22 Sep 2010 05:55 by ulda.
29 Nov 2010 22:25 #5753
by tlhiv
Replied by tlhiv on topic Re:Run EMC on Different OS?
ulda,
I've been a Gentoo users for years, but I was about to try to build EMC2 on a Gentoo system. You mentioned that you needed an ADEOS patched kernel for EMC2. Is there an ebuild for such a thing, or do you have to manually patch the kernel (I have no problem doing this). Also, I don't seem to see an ebuild for EMC2, so do you have a list of dependencies for EMC2 that must be installed prior to building EMC2?
Thanks!
Thanks!
