Checksum MD5 do not match from downloaded file
13 Aug 2021 23:00 #217714 by FredCailloux
Just downloaded the linuxcnc-2.8.2-buster.iso .
Did it twice.
Both downloads are identical files (tested).
Both files fail the MD5 checksum verification
I utilized Certutil on windows 7 to download the file
Command prompt:  certutil -hashfile linuxcnc-2.8.2-buster.iso MD5
My Check
4496eae88a1d66f457205d0d5b69c3c2
LinuxCNC page
41b71c4956c0c89033a99a590ebaefec
What do I do now ?
  • Moderator
  • Moderator
14 Aug 2021 00:47 #217719 by tommylight
Replied by tommylight on topic Checksum MD5 do not match from downloaded file
I would try to install it, maybe it works.
14 Aug 2021 01:36 #217721 by rodw
If not win32diskimager never fails
15 Aug 2021 12:21 #217804 by arvidb
I also downloaded linuxcnc-2.8.2-buster.iso using wget and get the same MD5 sum:
$ md5sum linuxcnc-2.8.2-buster.iso
4496eae88a1d66f457205d0d5b69c3c2  linuxcnc-2.8.2-buster.iso
Where did you find the other MD5 checksum? I cannot find any checksum files at the download site, nor any checksums printed on the download page .
It would be great if we could get automatically generated checksum files on the download server, and links to those in the text on the download page.
16 Aug 2021 12:37 #217878 by BigJohnT
Replied by BigJohnT on topic Checksum MD5 do not match from downloaded file
My guess is the documents were not updated when the iso was created.
JT
The following user(s) said Thank You: FredCailloux
16 Aug 2021 13:20 #217879 by andypugh
Replied by andypugh on topic Checksum MD5 do not match from downloaded file
I think that's a safe bet. I forgot.
I am re-doing the RTAI .deb tonight, I will try to remember to fix the documented MD5 too.
The following user(s) said Thank You: BigJohnT, joekline9
16 Aug 2021 16:27 - 16 Aug 2021 16:28 #217894 by FredCailloux
Replied by FredCailloux on topic Checksum MD5 do not match from downloaded file
arvidb , Here is where I got the MD5 verification code :  MD5SUM from LinuxCNC
 2.Then compare to these checksums
md5sum: 41b71c4956c0c89033a99a590ebaefec
sha256sum: a542092aa9f399d3ad50bbb2f0f4dd63ad9332c23d8387f6061bdd186d1df3b0
Last edit: 16 Aug 2021 16:28 by FredCailloux. Reason: forgot a detail
The following user(s) said Thank You: arvidb
16 Aug 2021 16:32 #217895 by FredCailloux
tommylight , I did just that . Installed it anyway. And guess what... its working fine. The main point is' If anyone is concerned with security and clean install IMO it a good first step to verify that the installation is done with a legitimate file.
In the mean time I will trust that my install is OK.
Cheers.
16 Aug 2021 23:56 #217935 by andypugh
I think that this is now fixed in the English, Spanish and Chinese docs.
The French docs are now so terribly out of date that I don't even know where to start.
Time to create page: 3.919 seconds
