LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
29 Mar 2024 22:58 - 29 Mar 2024 23:01 #297160 by phillc54
This message:
Is telling you that you had the same code for buttons #5 and #11, "torch-pulse" is only allowed on one button.
You can add buttons in PnCconf and also on the SETTINGS tab of the GUI.
linuxcnc.org/docs/devel/html/plasma/qtpl...#plasma:settings-tab
linuxcnc.org/docs/devel/html/plasma/qtpl...:custom-user-buttons
Last edit: 29 Mar 2024 23:01 by phillc54.
30 Mar 2024 02:59 #297184 by acourtjester
 Thanks PhllIn my last post I did fine another way to install custom button that worked without error.  I did have another problem come up when I tried to convert the SheetCam tools to the Material file for the GUI.  I followed the manual and all look fine but then had another error on start of the GUI.  I have attached the screen shot of the error and the resulting material file.  Not sure if the GUI did not like some of the syntax in the file as it talks about different line in the file.  Maybe a type of tool I had in SheetCam does not convert well for the GUI/LinuxCNC.  Not sure if the .RAR  files are uploaded for you to see.
File Name: tom_test_material.rar
File Size:1 KB
File Name: tomstools8-17-21.rar
File Size:1 KB
30 Mar 2024 03:29 #297187 by phillc54
I am sorry, that is a bug I have caused.
To work around it, edit the .prefs file, change [GUI_OPTIONS]Default material to 1 rather than 0.
I will push a fix as soon as I get it done.
30 Mar 2024 03:32 #297188 by acourtjester
Thanks again Phill
I will give the a try in the morning.
30 Mar 2024 03:55 #297189 by phillc54
A fix has been pushed.
30 Mar 2024 21:22 #297233 by acourtjester
Worked like a charm Thanks Phill
Time to create page: 1.584 seconds
