LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users
  • snowgoer540
  • snowgoer540's Avatar Topic Author
  • Moderator
  • Moderator
20 Mar 2024 10:11 #296384 by snowgoer540
Weird. I wonder what happens if I remove the hyperlink. Maybe that’s the problem?
20 Mar 2024 20:20 #296407 by acourtjester
Well I have blown most of the day trying to get things going. Linux seems to be constantly changing. I have gone through the install many times today and hit a brick wall.  First problem was getting the bios so it would see the hard drive after reboot, on this Dell it must be in legacy.  I did get it to do the install for MX and boot fine after that.  But down where update and upgrade section.  See attached screen shot, it could not fine the files to upload.  Also if you remove the USB stick before the install shuts down it will not shutdown on it own.  I keep getting the goal posts being moved.
What is bad is I talked a guy into going the linuxcnc way and I am unable to get my own table controller back running again.  It ran fine with axis for router work but plasma (QTPlasmaC) had glitches, so I looked for another version.  sorry for the whining ):  ):
  • Moderator
  • Moderator
20 Mar 2024 21:09 #296411 by tommylight
Screenshot is a network issue, namely there is no network connection at all, be it not configured or configured for Mesa, or bad cable/connectors not plugged all the way in.
See attachment, the first repo is active and working.
20 Mar 2024 23:34 #296416 by acourtjester
Thanks I got just about finished, this is the error I get when starting any of the QTPlasmaC operations
I have little experiences with Linuxcnc and don't know what or how to correct this.
This seems to be the last huddle.
21 Mar 2024 02:06 - 21 Mar 2024 02:09 #296424 by phillc54
Can you open terminal and post the result of these commands:
ls -l ~/linuxcnc/
ls -l ~/linuxcnc/nc_files/
l = lower case L
Last edit: 21 Mar 2024 02:09 by phillc54.
21 Mar 2024 02:21 #296427 by acourtjester
Thanks for the reply here is the result and the files for that QTPlasmaC.
File Name: files_2024-03-20.zip
File Size:7 KB
21 Mar 2024 02:30 #296428 by phillc54
Sorry, I may have edited my post after you saw it, could you do the two directories in the edited post.
21 Mar 2024 02:56 #296430 by acourtjester
hope this is what you want  (:  (:
21 Mar 2024 03:14 #296431 by phillc54
Give this a try, in the [RS274NGC] section of the .ini file change:
./:../../nc_files/plasmac/m_files
to:
./:../../nc_files/examples/plasmac/m_files
21 Mar 2024 03:24 #296432 by acourtjester
made change and here is the end of the report
Time to create page: 0.334 seconds
