Trying to install Linux CNC buster for router with 2 steppers on X axis
16 Oct 2021 16:59 #223306 by aaron
Hi
I need to set up a new machine similar to one already running.  It has two steppers running the X axis so I have Stretch 2.9.0-pre-1056-ge3548bc38  Stretch running on the original router.  I have installed Buster onto the computer running the new machine, but I am not sure what version and repository I need to get the new router working. Is this the repo?
buildbot.linuxcnc.org/ buster master-rtpreemp
and
buildbot.linuxcnc.org/ buster master-rtpreemp (sourceCode)
Thanks for your help
Aaron
18 Oct 2021 10:34 - 18 Oct 2021 12:08 #223442 by aaron
Hi
I have now installed linuxcnc-uspace via buildbot.linuxcnc.org/buster/master-rtpreempt .
when  I attempt to run a configuration I know works on another machine I get the following message on startup;
<commandline>:0: milltask exited without becoming ready
Waited 3 seconds for master.  giving up.
Note: Using POSIX non-realtime
stepgen: not loaded
<commandline>:0: exit value: 255
<commandline>:0: rmmod failed, returned -1
hal_parport: not loaded
motmod: not loaded
trivkins: not loaded
<commandline>:0: unloadrt failed
LinuxCNC terminated with an error.  You can find more information in the log:
    ########/linuxcnc_debug.txt
and
    ########/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal.
Also when I attempt to run stepconf wizard it says  "you are using a simulated-realtimeversion of LinuxCNC so testing of hardware is unavailable."
Any help would be appreciated
Last edit: 18 Oct 2021 12:08 by aaron.
18 Oct 2021 21:55 #223498 by BigJohnT
Stepconf default is to build a simulated hardware configuration unless you uncheck that option in the second screen. I missed that this morning when we spoke on the IRC, but when I thought of it you were gone...
I recommend you use 2.8 as it's stable and not subject to frequent breaking.
I recommend using the normal download in this link.
linuxcnc.org/docs/2.8/html/getting-start...#_download_the_image
JT
The following user(s) said Thank You: aaron
24 Oct 2021 09:15 #224075 by aaron
Thanks. I managed to ger her going with 2 8.
Much appreciated
Aaron
Time to create page: 0.071 seconds
