Problems with LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT
09 Nov 2021 12:54 - 09 Nov 2021 12:56 #225812 by RoberCNC
Hi everyone.I have installed LinuxCNC 2.8.0 Debian 10 Buster PREEMPT-RT with the idea of ​​testing and migrating my operational configuration but when I try to start I get the attached error, whether I copy the operational configuration folder or run the Pncconf Wizard.Thank you very much as allways.
Last edit: 09 Nov 2021 12:56 by RoberCNC.
  • Moderator
  • Moderator
09 Nov 2021 13:10 #225816 by tommylight
From the error report:
  File "/usr/bin/axis", line 3554, in <module>
    duplicate_coord_letters)
you have two of the same axis somewhere, meaning there are two AXIS X, or Y or Z or ...
There can be many joints for one axis, but only one of each axis.
The following user(s) said Thank You: RoberCNC
09 Nov 2021 13:26 #225819 by RoberCNC
Right, I have dual Y gantry. True as an arrow Tommy, just edit the INI file, delete a Y in "coordinates =" of section [TRAJ] and solved. I do not know what I feel more, if happy or stupid.
Thank you very much mate.
  • Moderator
  • Moderator
09 Nov 2021 13:34 #225820 by tommylight
Happy, for sure, we all make mistakes and miss things and ... i just try hard not to make mistakes when wiring electronics, everything else i am OK with mistakes.
09 Nov 2021 15:12 #225839 by RoberCNC
You're right, happy, :).
What would be the best option to migrate that same configuration to SilverDaragon or Probe_Basic?
I don't know if it can be done directly or if you have to build it little by little, step by step.
  • Moderator
  • Moderator
09 Nov 2021 15:23 #225841 by tommylight
No clue, did not have time to use them, got them running when they came out, drooled a bit and moved on . :(
Start by changing the Display section in the ini file:
display = axis
display = silver_dragon
Probably will require more changes that that, but that is all i recall now.
09 Nov 2021 15:29 #225843 by RoberCNC
Yes, thank you, I already see in the documentation that it is not as simple as changing Display, you have to go putting and directing all the subroutines and files. Thank you very much anyway Tommy, already having the axis configuration operational here I will try and modify with time, I think I have done all the wiring well: P.
Greetings.
Time to create page: 1.243 seconds
