What is the computer requirement for linuxcnc 2.8.2?
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Nov 2021 01:23 #225903 by Aldenflorio
The title is the question
10 Nov 2021 01:29 #225905 by tommylight
Anything from core2duo will work even with 1GB of RAM, more important is to have acceptable latency.
Old Dell Optiplex or Fujitsu are good, some HP like 8300 SFF are good, Dell, HP and Fujitsu Workstations are also good but pricey.
10 Nov 2021 02:14 #225909 by Michael
Also depends on what type of system you want to build. Paraport control will have a bigger dependency on latency and anything with and FPGA like mesa will not.
10 Nov 2021 11:17 #225953 by RNJFAB
I had a decent dell laptop and a good hp laptop. Both were not able to get decent latency and couldn't run linuxcnc.
Better to go with a PC not a laptop.
12 Nov 2021 00:32 - 12 Nov 2021 00:35 #226164 by my1987toyota
Replied by my1987toyota on topic What is the computer requirement for linuxcnc 2.8.2?
A Dell Optiplex 9020 SFF (or Micro if space is limited). A good SSD (Crucial MX500) and 8Gigs of ram are my current favorite.
I usually look for one with the Intel Core i5 CPU . Add in a Mesa 7i76E card and you have the makings of a good machine.
Last edit: 12 Nov 2021 00:35 by my1987toyota. Reason: updating info
  • Aldenflorio
  • Platinum Member
  • Platinum Member
12 Nov 2021 04:00 #226180 by Aldenflorio
I use the Mesa 7i96. Is the Mesa 7i76E better?
12 Nov 2021 11:04 #226213 by tommylight
No difference except IO, 7i76E has more inputs/outputs.
The following user(s) said Thank You: seuchato, my1987toyota
13 Nov 2021 00:06 #226256 by my1987toyota
tommylight post=226213 userid=17274No difference except IO, 7i76E has more inputs/outputs.
I guess I should have added that in my previous post.
13 Nov 2021 04:52 - 13 Nov 2021 04:53 #226283 by rodw
7i76e advantages:
more I/O
spindle control
2 x MPG
active high and active low are two different versions of the board
7i96 advantages:
can be active high or active low
Has 2 amp SSR relays on board
can get 5v logic power from field power.
but:
has fewer inputs and outputs
No spindle control,
no MPG inputs but can convert pins to get one if you can afford to giver up the limited number of inputs.
needs 2 power supplies (5v and field power)
Last edit: 13 Nov 2021 04:53 by rodw.
13 Nov 2021 09:40 #226290 by tommylight
Is the Field power 》logic power a 7i76E capability, not 7i96 ?
Time to create page: 0.261 seconds
