LCNC 2.9 RPI4 & Debian 11 (Bullseye) run in place make problem
4 years 11 months ago #227375 by nion
Thank you rodw. I installed libboost-python-dev but I have the same result.
But in the mean time I compared the differences between working Desktop and RPi4 with problems.
Seems that the boost_python is in the wrong place or the wrong version.
In the attached photos i put the logs from PC & RPi4 (Left column is PC log and Right column is RPi4)
At line 86(PC) and 80(RPi) it states "checking whether the Boost::Python library is available... yes" but at line 88(PC) 83(RPi) differences
begin to appear.
4 years 10 months ago #230446 by Boaschti
I had same Problem.
Fixed with installing:
libboost-python-dev
libboost-program-options-dev (not sure if it is necessary)
Add/replace in Makefile.inc:
BOOST_PYTHON_LIB=-lboost_python39
Look also here
4 years 1 week ago - 4 years 1 week ago #254862 by rdtsc
That almost worked for RaspiOS Bullseye, but it still complained of not being able to see the file, despite having `/usr/lib/arm-linux-gnueabihf/libboost_python39.so` and `/usr/lib/arm-linux-gnueabihf/libboost_python39.a` etc.
Solution was to install package `libboost-all-dev`.
Last edit: 4 years 1 week ago by rdtsc. Reason: Clarified context.
Time to create page: 0.070 seconds
