Installing LinuxCNC 2.8 on Debian 11
- BigJohnT
- Thank you received: 994
18 Dec 2021 13:36 #229397
by BigJohnT
Installing LinuxCNC 2.8 on Debian 11 was created by BigJohnT
I have Debian 11 installed and I'm not seeing any guides for installing LinuxCNC 2.8. Is there deb for Debian 11 or do I have to build one?
JT
JT
- Thank you received: 7478
18 Dec 2021 13:56 #229398
Replied by tommylight on topic Installing LinuxCNC 2.8 on Debian 11
There is 90% chances the Buster version will work, give it a try.
buildbot.linuxcnc.org/dists/buster/
The following user(s) said Thank You: BigJohnT
- BigJohnT
18 Dec 2021 15:05 #229405
by BigJohnT
Replied by BigJohnT on topic Installing LinuxCNC 2.8 on Debian 11
Error: Dependency is not satisfiable: libboost-python1.67.0
Guess I'll try and build a deb.
Hmm, no Python2 installed on Debian 11 either! I see it's still in the Debian 11 packages.
JT
JT
- BigJohnT
18 Dec 2021 15:50 #229408
by BigJohnT
I guess I should build and install the master branch...
JT
JT
18 Dec 2021 17:15 #229414
What about this:
www.forum.linuxcnc.org/18-computer/42057...-5-rt-amd64-download
- BigJohnT
18 Dec 2021 17:42 #229417
by BigJohnT
I already have a running system however there was a link in that thread to his notes on building which will help.
JT
JT
- Thank you received: 4149
18 Dec 2021 21:46 #229433
Replied by rodw on topic Installing LinuxCNC 2.8 on Debian 11
This is a good summary of getting going on Bullseye (11)
www.qtpyvcp.com/install/bullseye.html
The following user(s) said Thank You: BigJohnT, gitin
- BigJohnT
19 Dec 2021 17:08 #229497
by BigJohnT
It was actually very easy to get LinuxCNC going on Debian 11.
Opened the Synaptic Package Manager and searched for linux-image and selected the latest RT image and installed. Next a reboot and your in the RT kernel.
Cloned the LinuxCNC repo. Open a terminal in the directory and did the following.
Then right clicked on the deb and let Gdebi install it.
JT
sudo apt update
sudo apt dist-upgrade
sudo apt install libudev-dev bwidget intltool libboost-python-dev libepoxy-dev libgl1-mesa-dev libgtk2.0-dev libgtk-3-dev libmodbus-dev libeditreadline-dev libtk-img libusb-1.0-0-dev libxmu-dev netcat python3-dev python3-xlib tcl8.6-dev tclx tk8.6-dev yapps2 asciidoc dblatex docbook-xsl dvipng groff imagemagick inkscape python3-lxml source-highlight w3c-linkchecker xsltproc texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended asciidoc-dblatex texlive-xetex
debian/configure
dpkg-checkbuilddeps
debuild -uc -usThen right clicked on the deb and let Gdebi install it.
JT
The following user(s) said Thank You: arvidb, tommylight, gitin
- BigJohnT
19 Dec 2021 17:12 #229498
by BigJohnT
Oh yea I had to install mate-menu so I could uncheck then recheck all the CNC menu items so they would show up in the right place.
JT
JT
- BigJohnT
20 Dec 2021 13:45 #229556
by BigJohnT
The following user(s) said Thank You: tommylight, gitin
Time to create page: 0.213 seconds
