emc2-install.sh install dependency python
- abowyer1540
01 Oct 2010 02:56 #4462
by abowyer1540
emc2-install.sh install dependency python was created by abowyer1540
I've done all that I can think of to get this to install on 10.04. It installed on one laptop fine, the other not, both have same install of 10.04 and have all updates including latest Python.
wiki.linuxcnc.org/emcinfo.pl?Installing_...mpiled_EMC2_packages
"1.2. On Ubuntu 10.04 using precompiled EMC2 packages
If you have already installed Ubuntu 10.04 "Lucid Lynx", you can install emc2 without reinstalling your whole system. Simply download and run the installation scripts: "
--> I've done this --> linuxcnc.org/lucid/emc2-install.sh
I get this error, below, on executing the install script
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
emc2: Depends: python (< 2.6) but 2.6.5-0ubuntu1 is to be installed
Depends: python2.5-glade2 but it is not installable
Depends: python2.5-gnome2 but it is not installable
Depends: python2.5-imaging but it is not installable
Depends: python2.5-tk but it is not installable
Recommends: hostmot2-firmware but it is not installable
E: Broken packages
Ideas on what I can do to fix this??
E: Broken packages
01 Oct 2010 11:09 #4466
by BigJohnT
Replied by BigJohnT on topic Re:emc2-install.sh install dependency python
I would download the LiveCD and install from that. The link is on the left...
Time to create page: 0.076 seconds
