Live ISO runs but failing when installing Linux
- BMG
22 Jan 2022 19:22 #232810
by BMG
Live ISO runs but failing when installing Linux was created by BMG
Greetings,
I successfully created a LIVE usb. I can boot that up and run the live version of Linux/linuxCNC.
When I select install Linux (using the bootable USB) it fails saying it cannot locate the CD.
I an figuring I need to manually trigger the installation with the script pointing at the USB and not the CD.
I tried searching for USB installation but do not see similar requests.
Can anyone point me to a topic or a wiki page detailing how to install from a USB?
THanks.
FYI I am planning on using a Dell Optiplex 790 (I5). Initial latency tests look very good. (under 11,000 without any tweaking). Hard drive on machine is a wiped business drive so no functioning operating system on it yet.
THanks.
- BMG
22 Jan 2022 19:31 #232811
by BMG
Replied by BMG on topic Live ISO runs but failing when installing Linux
This is the 2.8.2 ISO - Failed to note that above. Downloaded it to a USB around Jan 1.
- ALittleOffTheRails
- Visitor
22 Jan 2022 20:10 #232813
by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Live ISO runs but failing when installing Linux
What utility did you use to write the image to the USB stick ?
win32diskimager is the preferred utility.
I think I saw somewhere that removing and reinserting the usb stick does the trick. In saying that I can't say that I've ever had that trouble.
- Online
- Thank you received: 7488
22 Jan 2022 20:11 #232814
Replied by tommylight on topic Live ISO runs but failing when installing Linux
Most users reported that just removing and inserting the USB works when this happens, give that a try.
- Visitor
22 Jan 2022 20:16 - 22 Jan 2022 20:18 #232815
Some more advice here:
forums.debian.net//viewtopic.php?f=17&t=132801
And here:
null-byte.wonderhowto.com/forum/fix-fail...-kali-linux-0177158/
And here:
Last edit: 22 Jan 2022 20:18 by ALittleOffTheRails.
- BMG
22 Jan 2022 20:17 #232817
by BMG
<Bangs head on wall>
Brilliant - Its installing as I type......
Perhaps a note on the download page stating to pull then reinstall if the USB if the installation complains about mounting the CD drive
Thanks Tommylight!
Thanks Tommylight!
Time to create page: 0.730 seconds
