Third time's a charm?
24 Jan 2022 20:12 #233004 by milu
Replied by milu on topic Third time's a charm?
I haven't tried that iso, but I've added the non-free firmware to the standard .iso. I get a completely clean boot (nothing called out by dmesg) but the blank screen after boot persisted. There is a known kernel bug that causes this, but it doesn't get fixed until a much newer kernel. I've installed Debian 11 and Linuxcnc 2.9 this morning. That all went really well, but the parallel port is not responding. Since you asked for details, I'll try to figure out how to tell which chipset it uses, but its the same exact board that was working, as recently as yesterday on the MSI (when it has 2.9 installed but not 2.8).
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
24 Jan 2022 21:41 #233016 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Third time's a charm?
Pick one machine to work with, install Linuxcnc and get it to boot.
Supply the info asked for regarding the parallel port as requested earlier. You were supplied with a link on how to do that.
Reread the post regarding the use of the Parallel Port Tester.
Please be consistent, swapping and changing is not helping.
Please try to approach this in a rational manner. You are not helping yourself.
24 Jan 2022 22:38 #233023 by tommylight
Replied by tommylight on topic Third time's a charm?
For black screen on Linux, see about adding "nomodeset" to the GRUB load line, right after "quiet splash", and do not forget to do a
sudo update-grub
after editing the
/etc/default/grub
with
sudo nano /etc/default/grub
so the line should look like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nomodeset"
The following user(s) said Thank You: ALittleOffTheRails
  • Visitor
  • Visitor
24 Jan 2022 22:45 #233024 by ALittleOffTheRails
I think you need to quantify that the first time you modify the kernel commandline is at the grub boot screen. Also it maybe an idea to delete quiet & splash so you can see the kernel messages.
24 Jan 2022 23:03 #233026 by milu
Thanks, I tried the nomodeset thing last night--no luck. There are lots of similar threads and that change helps some people, but not all. In my case, it made no difference.
Time to create page: 0.177 seconds
