Can not access network drive
4 years 8 months ago #234152 by kenwoodhf
Hope someone can help. I having been running Debian wheezy for my CNC machine and had no problems. I have a network drive on a Windows 7 system which the program can access with no problem. I have recently upgraded to Debian 10 buster and now I can not see my network drive. Searching the web a recommendation I found was to install gvfs-backends which got rid of an error message “ /ON”. Now when I open file manager and go browse network I get Windows Network which disappears when click on it.
4 years 8 months ago #234156 by d2inventory
did you try to type in the IP into the address bar in the file manager?
smb://192.168.x.y to access your win 7 machine or whatever your IP is.
what file manager are you using? (help -> about)
4 years 8 months ago #234223 by kenwoodhf
Thanks for the reply. My file manager is Thunar 1.8.4. I can ping the win 7 machine
from the terminal program but not form the address bar in file manager.
Jan
4 years 8 months ago #234244 by d2inventory
This is what I did to get it working:
sudo apt update
sudo apt install caja
sudo apt remove caja
sudo apt autoremove
This installs caja, which could make an smb connection to a windows machine. The caja package installed something to make it also work in thunar, I can't tell you for sure what it was but I guess if you just install samba-libs and libsmbclient it could also work without having to install caja and removing it again.
After doing this you can enter smb://192.168.x.y/ into the address bar and you should be able to browse your windows drive to find the folder you want.
Right click on the folder "Send To -> Side Pane" will add a shortcut to the left side under "Places". You can right click on that shortcut to rename it to something sensible.
Good luck :D
4 years 8 months ago #234315 by Todd Zuercher
The thing that caja installed that made thunar work was probably gvfs-fuse.
4 years 8 months ago #234320 by kenwoodhf
Thanks for your input. I followed your instructions
sudo apt update
sudo apt autoremove
but when I put in smb://10.0.0.251/ in the address bar I get
Failed to open File System
Failed to retrieve share list from server: invalid argument
I checked and samba-libs and libsmbclient are both already installed.
Thanks Jan
Time to create page: 0.320 seconds
