Can not access network drive
4 years 8 months ago #234323 by tommylight
4 years 8 months ago #234339 by d2inventory
Try installing the cifs-utils package
sudo apt install cifs-utils
maybe those are missing?
4 years 8 months ago #234350 by kenwoodhf
The cable company supplied me with a new router a couple of weeks ago. The ip address have changed. My win 7 box is 10.0.0.251 and my Debian box is 10.0.0.133.
When I put in ip a it does come back as 10.0.0.133
4 years 8 months ago #234351 by kenwoodhf
I installed cifs-utils and seems to be no change in opening network drives.
4 years 8 months ago - 4 years 8 months ago #234365 by d2inventory
Let's try a manual mount then.
sudo mkdir /mnt/winshare sudo mount -v -t cifs -o vers=2.1,username=YOURWINUSER,password=VERYSECRET //10.0.0.251/Users /mnt/winshare
if no error check if there is something in there
ls /mnt/winshare
You might need to change //10.0.0.251/Users to a directory you're sharing on the win box. I used Users to test for mine which worked, if you get an error try to change Users to c$ C$ or whatever is shared :D
Last edit: 4 years 8 months ago by d2inventory.
4 years 8 months ago #234494 by kenwoodhf
When I run Is/mnt/winshare I get
Default desktop.ini Guest Public
I am not very good using Linux system and I am confused trying to understand your next instructions
Time to create page: 0.159 seconds
