LinuxCNC is in debian now
4 years 7 months ago #236631 by aabtech
Now LinuxCNC has been accepted into the main Debian distribution how do we directly download package from apt ? .
4 years 7 months ago #236636 by rodw
Replied by rodw on topic LinuxCNC is in debian now
Yes, but its in the unstable branch at the moment and will get to testing in a week or so.
Testing will become Debian 12 Bookworm which will be the next Debian release.
You can try these steps I tested over the weekend and shared on another thread last night
Install a version of debian sudo apt install geany curl sudo geany /etc/apt/sources.list make sure any lines containing cd are commented out with a # replace any reference to bullseye, buster or stable with unstable eg: deb http://deb.debian.org/debian/ unstable main non-free contrib deb-src http://deb.debian.org/debian/ unstable main non-free contrib sudo apt update sudo apt full-upgrade sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash reboot type uname -a  (to check PREEMPT-RT kernel is running as its installed by the install) Linuxcnc should be in the menus or open a terminal and type: linuxcnc
The following user(s) said Thank You: my1987toyota
4 years 7 months ago #236758 by my1987toyota
It will be interesting to see everything work together in one download when that happens. Here's hoping. Though I will miss Linux Mint
and LCnC. I am still running the BeagleBrains special . 2.8.0
4 years 7 months ago #236891 by Todd Zuercher
It should filter down through to other Debian based distros eventually. But if you like Mint use LMDE. It usually isn't quite as polished as regular Mint, but it tends to be less Debain like than plain Debian, (mintier?) but still works with plain Debain repositories.
4 years 7 months ago #236913 by rodw
I might add that there is only one line to actually install linuxcnc in the script above.. In the next few weeks, it will filter down into their testing branch (aka Bookworm) so you could just grab a Bookworm ISO and you'd be in business.
PREEMPT_RT was installed as a dependency.
I had to give up Mint because they are too far behind for both hardware drivers and Python versions  to run linuxcnc on my PC whereas Debian has all the dependencies. Bullseye is quite nice even if a bit different..
4 years 7 months ago #236938 by tommylight
Bookworm has networking issues for now, the /etc/resolve.conf file is missing and a shortcut is in it's place, but it can not be overwriten.
That is to be expected as it in still in testing, just a heads up if someone want to test the "bleeding edge".
Time to create page: 0.172 seconds
