Other installation methods and compiling LinuxCNC
- Thank you received: 7468
18 Mar 2022 13:28 #237634
Other installation methods and compiling LinuxCNC was created by tommylight
This is a continuation of the discussion started here so it got out of topic a bit there.
Putting it here so it is easier to find.
forum.linuxcnc.org/plasma-laser/44961-th...deas?start=20#237362
18 Mar 2022 13:49 #237638
Replied by tommylight on topic Other installation methods and compiling LinuxCNC
It was early in the morning .... THIS IS NOT A GUIDE, use at your own risk, be ready to reinstall at random
After the last nights chat on the link above, despite my eyes hurting badly and greatly deprived of sleep, i went the "Nuclear" route:
-Install Linux Mint 20.3 Mate edition
-Add the Debian unstable/testing/bookworm/"do not go there" repos in /etc/apt/sources.list
-sudo apt update < will complain about missing keys, google, paste
-sudo apt full upgrade < it requires downloading and installing over 1600 packages, grab a coffe
-it will fail during update
-sudo apt -f install < will continue and finish
-sudo apt full upgrade < will download some other small stuff and finish, will ask to change the existing stuff, hit enter
-sudo apt install linuxcnc-uspace linuxcnc-uspace-dev mesaflash <will download and install a lot of other stuff together with RT kernel, but i did install the kernel before this, so i have to recheck
-will fail
-sudo apt -f install <will finish ok
-reboot
-aaaand boots with no GUI, so log in and type "startx"
-WORKS !
QtPlasmaC starts and works in SIM, so assuming it will work properly. Still room for improvement, disabling old and partner and source code repositories should speed this up a lot. And maybe not break autologin ...
-will fail
-reboot
-WORKS !
- Thank you received: 4145
18 Mar 2022 20:29 - 18 Mar 2022 20:34 #237671
Replied by rodw on topic Other installation methods and compiling LinuxCNC
Installing linuxcnc on Debian Sid
Lets not make this harder than it needs to be:
1. Download and Install the Debian mini ISO from ftp.debian.org/debian/dists/sid/main/ins...rent/images/netboot/
2. Be sure to select sid when requested
3. Boot into the new OS and log in
4. Click on Activities top left
5. Type syn to search for Synaptic, Click on the Synaptic icon and type your password when requested
6. Click on search top right and type linuxcnc
7. Click on the checkboxes and mark for installation the following:
linuxcnc-uspace, linuxcnc-uspace-dev, your preferred language, mesaflash (if you have a mesa card)
8. Click on apply twice
9. Go and have a coffee while it installs
10. When done, reboot into the PREEMPT_RT kernel and you are done with no terminal commands!!
If you need help installing the mini ISO in step 1, follow this guide haydenjames.io/direct-install-debian-sid...i-iso-w-screenshots/
Linuxcnc can be found under the 9 dot applications icon when you click on Activities
To save a shortcut to linuxcnc click Activities, type linuxcnc, right click and add to favourites.
You can access Debian settings and network settings by clicking on the region with the power icon at top right
Last edit: 18 Mar 2022 20:34 by rodw.
18 Mar 2022 20:43 #237672
Try typing :to select your preferred desktop. It should load on startup
Tommy,-aaaand boots with no GUI, so log in and type "startx"
-WORKS !
Try typing :
sudo tasksel
18 Mar 2022 22:01 #237682
Very nice, but no cigar!
Mini will not work on most of my stuff due to network drivers, i did try that twice, There was no non-free version back when i did.
Thank you very much, i still have some old stuff around to test on, and i know some new stuff works with it, me insisting on having Intel networking does not.
19 Mar 2022 03:11 #237703
cdimage.debian.org/cdimage/unofficial/no...ds/amd64/iso-hybrid/
I used xfce
and follow the instruction on debian to upgrade to unstable
wiki.debian.org/DebianUnstable
Hopefully, some packages are shared so it may be faster than using bullseye which also works.
In that case, it would probably be best to install the nonfree version of testing by choosing an ISO from here:Very nice, but no cigar!
I used xfce
19 Mar 2022 11:40 - 19 Mar 2022 19:19 #237708
I got this far with Mint 20.3:
-will fail
-reboot
-WORKS !
Notice that it did not finish full upgrade, but was enough for LinuxCNC to install and work and GUI starts as usuall.
-will fail
-reboot
-WORKS !
Last edit: 19 Mar 2022 19:19 by tommylight. Reason: more info
19 Mar 2022 19:17 #237735
Linux Mint Debian Edition 4 or LMDE4 :
Install, reboot, add repositories, full upgrade = gets stuck at replacing crypto-something to the point it is useless as anything typed in a terminal will result in "wrong password provided 3 times, try again".
Fail!
Will try less "Nuclear" options later.
Fail!
20 Mar 2022 23:39 - 27 Mar 2022 23:29 #237862
It will download over 1400 packages, but works without a hitch.
I used the Mate version, i always use the mate version as it is the only DE that has configurable task panels, control freak so i need my dose of temps and speeds and voltages and loads and ... nevermind.
Even the installer located on the live desktop worked. Makes things simpler for new users.
Although, this is much simpler than compiling, it is "unstable" so if taking this route be ready to do reinstalls at random and without warning, so keeping backups of configs should be mandatory.
Thoughts? Ideas? Stones? Throw them my way!
Well, this works!In that case, it would probably be best to install the nonfree version of testing by choosing an ISO from here:
I used xfce
Last edit: 27 Mar 2022 23:29 by tommylight. Reason: typo
21 Mar 2022 04:08 #237873
I don't think unstable really means unreliable. It is and I quote, the rolling development version containing the latest packages
There are other distros that run off this as standard.
There is also an experimental branch of debian.
just recapping,
edit /etc/apt/sources.list so all it contains is
With a minimalist install, probably the smallest editor to install is nano so it becomes
replace the contents of this file with :[/code]
Then
I really think diving into Linux mint is just making more work and trebles
just recapping,
deb http://deb.debian.org/debian/ unstable main
deb-src http://deb.debian.org/debian/ unstable mainWith a minimalist install, probably the smallest editor to install is nano so it becomes
sudo nano apt install
sudo nano /etc/apt/sources listreplace the contents of this file with :
deb-src http://deb.debian.org/debian/ unstable mainThen
sudo apt update
sudo apt upgrade fullI really think diving into Linux mint is just making more work and trebles
Time to create page: 0.121 seconds
