- LinuxCNC
- Installing LinuxCNC
- (solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
- SertanATL
05 Apr 2022 13:44 #239335
by SertanATL
(solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install. was created by SertanATL
I am trying to install LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO to my HP 8300 Elite computer using usb stick.
Bios settings: Legacy Boot enabled, Secure Boot Disabled. EUFI is enabled, installer won't run on legacy.
While installing, installer crashes while IPV6 installation.
In order to avoid this problem I disconnected the pc from the internet. Now I get Install Fail: 'grub-efi-amd64' package failed to install into /target/ problem.
I created the usb stick using Win32 DiskImager and Rufus, no differance.
I read other topics about this but I could not find any solution.
I wanted to install Debian 7 Wheezy ISO but it does not boot at all.
I previously installed Mx19.4 and installed Linuxcnc but it had over 1.000.000 latency.
How do i install LinuxCNC?
- Thank you received: 7488
05 Apr 2022 14:53 #239338
Replied by tommylight on topic (solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
Disable UEFI.
- SertanATL
05 Apr 2022 17:23 #239363
by SertanATL
Replied by SertanATL on topic (solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
When I diable UEFI pc cannot boot to usb stick. It cant find something to boot to and sits on black screen. What am i doing wrong?
- scotth
- Thank you received: 62
05 Apr 2022 17:40 #239364
by scotth
Replied by scotth on topic (solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
I have had some luck using the DD option in Rufus when ISO fails.
I don't know if it will help, but it has worked for me.
Look at
trendoceans.com/how-to-create-a-bootable...linux-distributions/
Look at
- Thank you received: 4150
05 Apr 2022 20:40 #239383
Replied by rodw on topic (solved) LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO Failing to install.
This is just another reason why I always use Debian Bullseye as the later kernel has UEFI support and a host of drivers for more recent hardware (and I use Rufus to make the usb stick)
Install instructions
www.qtpyvcp.com/install/bullseye.html
- SertanATL
06 Apr 2022 06:20 #239416
by SertanATL
Thanks for the advice!
I tried DD option but no luck unfortunately.
06 Apr 2022 07:09 #239418
If it helps, I burnt a copy of Debian Bullseye (11.3) nonfree to a DVD today and installed it on a MSI All in one i3 PC because it preferred a DVD to boot to.
I installed the preempt_rt patch using synaptic (search for linux-image) and also linux-headers for that kernel while I was there.
Then instead of using the link I provided earlier in this thread, I decided to use this script
github.com/joco-nz/lcnc-bullseye-installer
I realised then I needn't have bothered installing the preempt_rt image as the script does it for you
It worked flawlessly. It asked a few questions along the way but when done, I had linuxcnc in the menus
The script was written by James who also wrote the instructions linked earlier so I expected it to be perfect!
The following user(s) said Thank You: SertanATL
- SertanATL
06 Apr 2022 09:32 - 06 Apr 2022 09:34 #239426
by SertanATL
I downloaded latest Debian from their website and ran the script as you said and it worked flawlessly!
You are a great help rodw, thank you!
Edit: SOLVED!
Edit: SOLVED!
Last edit: 06 Apr 2022 09:34 by SertanATL.
06 Apr 2022 13:03 #239442
Great to see you got a result!
Debian Bullseye with a later kernel has a greater range of hardware support.
Its a nice system to use and worth the bit of extra effort to get up and running.
And to think you managed to install it based on on paragraph of instructions without wading through pages of instructions required for MX linux!
- LinuxCNC
Time to create page: 0.342 seconds
