Screen Saver
  • Nitram
  • Nitram's Avatar Topic Author
  • Elite Member
  • Elite Member
10 Apr 2022 04:16 #239798 by Nitram
Screen Saver was created by Nitram
Hi.
Was using the mill today after the Deb 10/Buster/LCNC 2.8.2 .iso install.
Linuxcnc was running at the time and after a while the screen went blank and I had to log in again to re-display Linuxcnc.
I have already entered the following:
sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
to prevent any sleeping/hybernation...
but:
1. where/how do I disable the above from happening?
2. is what I have done via terminal sufficient or are there settings elsewhere to prevent sleeping or applying a screen lock?
Thanks!
10 Apr 2022 08:27 #239803 by robertspark
Replied by robertspark on topic Screen Saver
packages.debian.org/buster/xfce4-power-manager
sudo apt install xfce4-power-manager
you can disable the locked screen plus the screen blanking etc.... have a look at each of the tabs once installed
  • Nitram
  • Elite Member
  • Elite Member
10 Apr 2022 20:47 #239857 by Nitram
Replied by Nitram on topic Screen Saver
Also found more info and other solutions, so link attached here for further reference.
Thanks everyone!!
forum.linuxcnc.org/38-general-linuxcnc-q...nuxcnc-debian-buster
Time to create page: 0.232 seconds
