Sense checking my plan for 'moving' from Mach3.
- Gordon49
- Thank you received: 5
04 May 2022 13:46 #241978
by Gordon49
Replied by Gordon49 on topic Sense checking my plan for 'moving' from Mach3.
Ask around! people are chucking out "old" desktops with icore5 processors. I have two of them, one running a standard install of 2.8 with gmoccapy running the mill.
I did try to use a laptop but the latency was awful!
The other has the debian testing install, also with Gmoccapy, both have parallel ports cards, pcie type. both work fine. I generally prefer the the 2.8 -- series for serious metal cutting in case there are stability issues.
To use the testing install I just swap the cables.
Both came with monitors, bit old but so what?
Later when you feel the need or want you can change to a mesa card and add all the extra facilities that are available with them.
- Thank you received: 4652
04 May 2022 20:50 #242003
www.ebay.co.uk/itm/185130705221
(I paid £99 for a core-i3 280Mhz and it gives 3-figure latency numbers.)
Not a touch-screen, just in case you thought it was.
Replied by andypugh on topic Sense checking my plan for 'moving' from Mach3.
Guessing that you are in the UK, these have splendid latency:Ask around! people are chucking out "old" desktops with icore5 processors.
- Gordon49
10 May 2022 18:15 #242512
by Gordon49
Yes you are correct! in bucks
but freebay is your friend.
Time to create page: 0.108 seconds
