Installation, PC want's to mount a CD-ROM!!! Why and how please?
- SimonCNC123
- Thank you received: 5
20 Apr 2022 01:59 #240714
by SimonCNC123
Installation, PC want's to mount a CD-ROM!!! Why and how please? was created by SimonCNC123
Hi Folks, I know it's not really a CNCLinux issue but I am trying to install Debian 10 (linuxcnc 2.8.2 - buster iso) on a Dell Vostro 320 PC, I am using an SD card installed in a USB card reader. When I boot the PC and start the installation, I get to a point where it wants to detect and mount a CD-ROM. As I am not using a CD-ROM , I can't get past this point in the installation, and I don't know how to point it to the USB drive instead! Any help please?
BTW, I have just completed a successful retrofit of a Multicam 140 XYZ Router with a Mesa 7i76 card, I'll post some info shortly.
Cheers S
Cheers S
- Thank you received: 7488
20 Apr 2022 08:49 #240720
Replied by tommylight on topic Installation, PC want's to mount a CD-ROM!!! Why and how please?
When it asks for a CD, remove the usb, wait 10 seconds, insert the usb, wait 10 seconds, hit enter.
Usually this moves things along.
- SimonCNC123
21 Apr 2022 03:23 #240776
by SimonCNC123
Replied by SimonCNC123 on topic Installation, PC want's to mount a CD-ROM!!! Why and how please?
Thanks very much, that worked. Unfortunately it looks like the PC has other issues with bad drive sectors. I have my system up and running perfectly with a Raspberry Pi 4 but I want to run Probe Basic and have not found a straight forward description of how to install it on a pi. I get stuck at the section in the tutorial where I have to set the ProbeBasicInstaller file to run as a program, The Buster OS on the Pi doesn't give this option and I haven't been able to launch the program any other way!
21 Apr 2022 10:53 #240787
In a terminalThat makes it executable even on RPI.
sudo chmod +x name_of_the_installer_filePlease Log in or Create an account to join the conversation.
- SimonCNC123
23 Apr 2022 07:09 #240969
by SimonCNC123
Thanks, I'm getting these errors when I run the installer file:
pi@linuxcnc:~/probe_basic $ sudo ./ProbeBasic-Installer-py2+3.g231c7ff.run
./ProbeBasic-Installer-py2+3.g231c7ff.run: 1: ./ProbeBasic-Installer-py2+3.g231c7ff.run: ELF: not found
./ProbeBasic-Installer-py2+3.g231c7ff.run: 2: ./ProbeBasic-Installer-py2+3.g231c7ff.run: @!: not found
./ProbeBasic-Installer-py2+3.g231c7ff.run: 3: ./ProbeBasic-Installer-py2+3.g231c7ff.run: Syntax error: "(" unexpected
This is on a Raspberry Pi 4 running all the versions suggested in the installation instructions, and having followed the update and PyQt installs.
- Elco
- Thank you received: 3
24 Apr 2022 15:16 #241073
by Elco
Replied by Elco on topic Installation, PC want's to mount a CD-ROM!!! Why and how please?
I am running into the same problem on a Biostar mini-ITX board. But I boot from an SSD (loaded with the linuxcnc 2.8.2 - buster iso). Running live is fine, but when I request installation, it hangs in the same CD-ROM loop. I have no USB to remove, and it did not like unplugging the SSD at all...
Is the current ISO not made for a regular installation?
Elco
Elco
24 Apr 2022 17:16 #241087
It can not be done without a USB or a DVD.
Well it can, but not easy at all.
27 Apr 2022 21:40 #241406
This issue with looking for a DVD is a problem with the Debian installer, and is only found on a subset of machines. You might find more answers looking on generic Debian forums.
Replied by andypugh on topic Installation, PC want's to mount a CD-ROM!!! Why and how please?
Is that SSD meant to be the boot drive? The ISO is a bootable ISO image, but is really intended to be an installer and test environment.I am running into the same problem on a Biostar mini-ITX board. But I boot from an SSD (loaded with the linuxcnc 2.8.2 - buster iso).
27 Apr 2022 23:25 #241414
He has written the ISO image to SSD and is booting the PC from it and at the same time trying to install on that same SSD.
28 Apr 2022 23:33 #241587
I wonder if that can ever work?He has written the ISO image to SSD and is booting the PC from it and at the same time trying to install on that same SSD.
Time to create page: 0.123 seconds
