LCNC 2.9 uspace Debian 11 Packages:
repository.qtpyvcp.com/repo/linuxcnc_debs/
These were built back in April of this year.
LCNC 2.9 installed without any issues on Deb11 until a few weeks ago.
"po4a 0.62 in bullseye is too old, it also cannot build our docs
we need 0.66 from bookworm/testing and unstable
it also looks like DEB_BUILD_OPTIONS=parallel=N is no longer honored, so that'll make the build times longer too"
For RIP:
username@debian11:~/dev/rip/src$ make
emc/Submakefile:4: warning: overriding recipe for target '../include/linuxcnc.h'
emc/Submakefile:4: warning: ignoring old recipe for target '../include/linuxcnc.h'
Reading 205/205 dependency files
Done reading dependencies
Reading 230/230 realtime dependency files
Done reading realtime dependencies
You now need to run 'sudo make setuid' in order to run in place with access to hardware.
cd rip
source scripts/rip-environment
you may need to add a line like this one to your ~/.bashrc
source /home/username/Projects/linuxcnc/scripts/rip-environment
RIP works on Deb11 with some changes to the install instructions. I'm building on Sid later. I'll post an update.
