Installing LinuxCNC master on Ubuntu 18.04 with RT-Preempt
- rocksing
02 Jul 2022 13:04 #246437
by rocksing
Installing LinuxCNC master on Ubuntu 18.04 with RT-Preempt was created by rocksing
Dear all,
I am trying to install LinuxCNC master (2.9) on Ubuntu 18.04 with RT-Preempt. But I come with the errors from the boost python. Is there any hints on this issue?
/emc/task/taskintf.o objects/emc/motion/dbuf.o objects/emc/motion/stashf.o objects/emc/task/taskmodule.o objects/emc/task/taskclass.o objects/emc/task/backtrace.o ../lib/librs274.so.0 ../lib/liblinuxcnc.a ../lib/libnml.so.0 ../lib/liblinuxcncini.so.0 ../lib/libposemath.so.0 ../lib/liblinuxcnchal.so.0 ../lib/libpyplugin.so.0 ../lib/libtooldata.so.0 -Wl,-rpath-link,../lib -Wl,-Bsymbolic-functions -Wl,-z,relro -Wl,-z,now -Xlinker -export-dynamic -Wl,-O1 -Wl,-Bsymbolic-functions -lboost_python-py36 -L/usr/lib -lpython3.6m -lpthread -ldl -lutil -lm
objects/emc/task/taskmodule.o: In function `boost::python::objects::make_holder<0>::apply<boost::python::objects::pointer_holder<boost::shared_ptr<TaskWrap>, TaskWrap>, boost::mpl::vector0<mpl_::na> >::execute(_object*)':
/usr/local/include/boost/python/object/make_holder.hpp:92: undefined reference to `boost::python::instance_holder::allocate(_object*, unsigned long, unsigned long, unsigned long)'
- Thank you received: 7488
02 Jul 2022 13:09 #246438
Replied by tommylight on topic Installing LinuxCNC master on Ubuntu 18.04 with RT-Preempt
Is there any particular reason for using 18.04?
2.9 will not work on it as it requires Python 3 to run, while 18.04 uses Python 2.
Check the "installing LinuxCNC" section of this forum, there are pinned tutorials on how to get 2.9 on Debian and Linux MX.
The following user(s) said Thank You: joekline9
Time to create page: 0.092 seconds
