Installing LinuxCNC 2.9 or Master on Linux Mint 21
3 years 9 months ago #261702 by tommylight
Why i am on parport ?
I did not ask, i absolutely love parallel port since the days of bad floppies and parallel being very good at transferring data very fast for the time. FX.exe ??? Anyone? :)
F35 have ~11 milion lines of source code and runs on three paralell os..
That is why they never work, cost extortionate amounts of money, and orders getting canceled daily! The culmination of "get some engineers from (enter 3'rd world country) to build the most complicated (insert equipment/project/software of choice)" then present that to public as "the best thing since sliced bread" and subsequently failing monumentally, while people end up with the bill showed so deep down their throat ....
F35 would have been much better if they used 11 parallel ports, it would work and work reliably! :)
The following user(s) said Thank You: Stanislavz
3 years 9 months ago - 3 years 9 months ago #261707 by Ismacr63
Do you know if it is possible to install linux mint 21 and linuxcnc 2.9 rtai kernel?
Last edit: 3 years 9 months ago by Ismacr63.
3 years 9 months ago #261708 by tommylight
I did try on Mint 19 and it worked, i did not try on Mint 21 so i do not know if it works.
The following user(s) said Thank You: Ismacr63
3 years 9 months ago #261712 by Ismacr63
I have tried to install it but the system does not boot. I still haven't installed the correct files...
3 years 9 months ago #261749 by Stanislavz
Does it show anything ? Grub menu ? Some lines after it ?
3 years 9 months ago #261752 by Ismacr63
after it ?
I can select the kernel in the grub menu and I get this message:
Kernel doesn't support EFI handover
Time to create page: 0.352 seconds
