Network. Nothing happens when I press "Edit connections"
17 Jul 2022 18:43 #247579 by Kevin_Pawlus
Hi all :)
I just installed LinuxCNC Debian 2.8.2 and I have some difficulties to get the network to function. Internet is working, I'm trying to connect my Mesa 7i94 but nothing happens when I press the button "Edit connections". I've tried restart the computer.
17 Jul 2022 19:00 #247582 by JT
gnipsel.com/linuxcnc/uspace/debian9-eth.html
You need to edit /etc/network/interfaces, network managers don't have a clue...
JT
18 Jul 2022 14:24 #247675 by Kevin_Pawlus
I did try that, could not get it to work...
Maybe should try one more time.
I edited the connection in network manager lite the pictures. I did also tried the guide on this forum but also no result...
18 Jul 2022 14:32 #247679 by PCW
Is the 7I94 jumpered for 10.10.10.10 and connected?
What does
ip a
report
18 Jul 2022 14:35 #247680 by Kevin_Pawlus
The board is connected and the jumpers on the Mesa are as default.
18 Jul 2022 14:45 #247687 by PCW
Default jumpers would set the 7I94 IP address to 192.168.1.121
18 Jul 2022 14:48 #247688 by Kevin_Pawlus
I changed jumper W5 and it's working now!
Really glad for the help, this problem was annoying to me
18 Jul 2022 16:17 #247705 by Kevin_Pawlus
I cant find 7i94 in pncconf when I try to setup.
Im not sure why.. Can I add 7i94 to pncconf or should I do something else?
18 Jul 2022 16:27 #247707 by PCW
pncconf does not support the 7I94 but you should be able to create a configuration for a 7I92
that will work if you change the card name in the ini file
(select the "Use INI substitution for Mesa board names" option)
18 Jul 2022 19:18 #247721 by Kevin_Pawlus
Thanks, I got a little bit further now.
There is several options to choose firmware, I'm not sure which one to use.
It seems like the setup I made using 7i92 and changing the INI file to 7i94 is for stepper motors.
I have an 7i77 analog board connected to my 7i94 and my machine is using +-10v to control the servomotors.
Time to create page: 0.129 seconds
