LinuxCNC build for debian running a 5.0.0 Kernel
- isdicnc
28 Jul 2022 00:45 #248495
by isdicnc
LinuxCNC build for debian running a 5.0.0 Kernel was created by isdicnc
Is there a linuxCNC distribution that supports a newer version of the linux kernel? i.e. > 5.0.0
I just bought an ASUS motherboard that the screen buffer in older versions of the kernel 4.0.0 do not support.X fails to load.
len
len
- arvidb
- Thank you received: 158
28 Jul 2022 01:24 #248498
by arvidb
Replied by arvidb on topic LinuxCNC build for debian running a 5.0.0 Kernel
There are several ways of doing this:
1) If you can get the machine to boot (e.g. editing the kernel command line in grub to include nomodeset) then you should be able to install a newer kernel - from debian backports perhaps? I'm hazy on the details but instructions should be pretty easy to find.
2) Start with e.g. an official Debian 11 (Bullseye) distro (comes with linux-5.10) and install linuxcnc onto this. I think you'll need to build linuxcnc from source due to python dependencies, but this is not difficult: see the instructions .
3) Perhaps you can find links to some ready-made "unofficial" linuxcnc distro with a new enough kernel if you look around a bit here on the forum.
- isdicnc
28 Jul 2022 02:51 #248500
by isdicnc
Replied by isdicnc on topic LinuxCNC build for debian running a 5.0.0 Kernel
Cool, I'll go with option 2. Probably the cleanest.
Thanks for the quick reply.
len
len
- Thank you received: 4149
28 Jul 2022 21:28 #248591
Replied by rodw on topic LinuxCNC build for debian running a 5.0.0 Kernel
Quickest way is to install Debian Testing nonfree (aka Bookworm v 12). That gets you to about 5.17. You can get this from the amd64 weekly builds here
cdimage.debian.org/cdimage/unofficial/no...-including-firmware/
use the iso-cd version.
then open a terminal window and type:
sudo apt install linuxcnc-uspace
and optionally:
sudo apt install linuxcnc-uspace-dev
thats it!
Debian 11 (bullseye) does not help much. It gives you the 5.10 kernel but you need to build linuxcnc from source when Bookworm has the packages builtin.
It is possible to upgrade a Debian 11 system to Debian 12 but I'll let you google how to do that...
and optionally:
thats it!
- isdicnc
04 Aug 2022 18:57 #249062
by isdicnc
I finally got around to installing Debian 12 and linuxcnc as per your instructions above. Yep, much faster than going from source. Thank you!
Any idea the time line before Debian 12 goes final?
len
len
- isdicnc
04 Aug 2022 19:09 #249063
by isdicnc
A few follow up questions.
With the linuxcnc-uspace-dev does that bring over the linuxcnc source tree, or just the dependencies?
Second... The kernel that comes with Debian 12 shows a SMP PREEMPT_DYNAMIC version. DOes that need to be updated to a RT kernel?
len
len
- JT
- Thank you received: 593
04 Aug 2022 20:37 #249067
by JT
Replied by JT on topic LinuxCNC build for debian running a 5.0.0 Kernel
SMP PREEMPT_DYNAMIC is just a new name for a stock kernel, fooled me once...
linuxcnc-uspace-dev does not bring in the source only functions like the HAL Component Generator that don't get installed with the normal linuxcnc-uspace.
JT
JT
- isdicnc
04 Aug 2022 23:11 #249081
by isdicnc
From what I read the realtime kernel is necessary to run on a machine tool.
From section 2.2. linuxcnc.org/docs/master/html/code/building-linuxcnc.html
"LinuxCNC can also be built and run on non-realtime platforms, such as a regular install of Debian or Ubuntu without any special realtime kernel."
So does the Debian package from above need to be recompiled to support a RT kernel? Of if I upgrade Debian 12 with an RT kernel first will the above command install linuxCNC that supports a RT kernel?
"In this mode LinuxCNC is not useful for controlling machine tools, but it is useful for simulating the execution of G-code and for testing the non-realtime parts of the system (such as the user interfaces, and some kinds of components and device drivers)."
Time to create page: 0.169 seconds
