Asus Prime A520M-K No X Window system
- ChathamDaleJ
03 Aug 2022 03:17 - 03 Aug 2022 03:41 #248894
by ChathamDaleJ
Asus Prime A520M-K No X Window system was created by ChathamDaleJ
After installation, X fails to start, complains that it cannot open a framebuffer.
Graphics is onbard, Radeon HD 5880
I suspect the drivers for the graphics card are not being installed.
Help!!!!
Help!!!!
Last edit: 03 Aug 2022 03:41 by ChathamDaleJ. Reason: Adding log
- Thank you received: 7480
03 Aug 2022 07:43 #248906
Replied by tommylight on topic Asus Prime A520M-K No X Window system
What are you installing?
- ChathamDaleJ
03 Aug 2022 09:44 #248911
by ChathamDaleJ
Replied by ChathamDaleJ on topic Asus Prime A520M-K No X Window system
LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO
03 Aug 2022 10:30 #248915
At boot time, GRUB menu press E and add "nomodeset" after "splash", enter.
See if that makes it boot.
- ChathamDaleJ
03 Aug 2022 12:02 - 03 Aug 2022 12:03 #248922
by ChathamDaleJ
"splash" does not appear in the grub configuration. I added at the end of the line starting with "linux".
Booted same problem.
Last edit: 03 Aug 2022 12:03 by ChathamDaleJ. Reason: Add the result
- ChathamDaleJ
03 Aug 2022 15:21 #248938
by ChathamDaleJ
How flaky is the sid distribution from Debian and does it install with LinuxCNC ready to run?
- Online
- Thank you received: 1476
03 Aug 2022 17:06 #248953
Replied by Todd Zuercher on topic Asus Prime A520M-K No X Window system
The flakiness isn't so much in running. (It usually runs fine.) The flakiness is in the interaction of changing dependencies when ever an update or software installation is performed. You can never know if your system and all of it's parts will still work or even still be installed the next time you update.
- ChathamDaleJ
03 Aug 2022 21:00 #248971
by ChathamDaleJ
Is sid the only distribution containing LinuxCNC?
If so, is this the right link to install: mirrors.edge.kernel.org/debian/dists/sid...ller-amd64/20210731/
Thanks,
Dale
Thanks,
Dale
- Online
04 Aug 2022 13:02 #249030
No, it is also in Testing (Bookworm). Or was last time I checked (I have it installed as such in a VM.)
- ChathamDaleJ
05 Aug 2022 02:21 #249092
by ChathamDaleJ
is there a relatively inexpensive graphics card know to work with LinuxCNC 2.8.2 out of the box?
Time to create page: 0.263 seconds
