Building a kernel
17 Oct 2010 16:37 #4723
by pcnc1
Building a kernel was created by pcnc1
Hi there.
I am building a kernel so I can use RTAI to run emc2 here and I am using instructions from:
wiki.linuxcnc.org/emcinfo.pl?Debian_Lenny_Compile_RTAI
And I have come across this line:
Power management and ACPI options ---> ACPI (Advanced Configuration and Power Interface) Support ---> Dock ---> enabled [*]
I cannot figure out what the asterisk refers to. I also do not understand why I need to enable "Dock".
Can anyone here help me clarify any of this? Thanks.
17 Oct 2010 23:33 #4730
by mozmck
Replied by mozmck on topic Re:Building a kernel
The asterisk shows the option is enabled in the kernels 'menuconfig'
I believe "Dock" is enabled because it is required by something else, and you can't disable it.
18 Oct 2010 09:57 #4737
Replied by andypugh on topic Re:Building a kernel
pcnc1 wrote:
You might also like to look at the instructions here:
neo-technical.wikispaces.com/emc2-ubuntu
18 Oct 2010 12:53 #4740
by pcnc1
Replied by pcnc1 on topic Re:Building a kernel
Yes I have been noticing that it just seems turned on. I guess that is what bugged me
and why I posted my question. I cannot figure out why I get stuck with it. I'm trying to configure
a kernel with as little of what I don't need as I can. But it is hard for me to figure out what I don't
need. Turning off "Dock" seemed like a no brainer to me.
From what little I can gather it seems "Dock" has something to do with docking stations?
Why I *need* that on a desktop system I don't know. But whatever right?
I did decide shortly after I left my post to just let it go. But it is still bugging me. I'll live though.
I keep on getting hit by the IPIPE. I know I need that, and the last time I went through the menu
I couldn't find the thing!
I'll get this whole kernel configuration thing eventually. Thanks for your help.
18 Oct 2010 13:01 #4742
by pcnc1
Much appreciated! I am on my way to check it out now. The other day I think I found where that
other page of instructions came from.
www.lara.unb.br/~phsantana/data/files/te...HowTo_RTAI_Linux.pdf
Looks very similar to me. But I haven't checked out your link yet. I can use all the help
I can get. So thank you.
23 Oct 2010 08:45 - 23 Oct 2010 11:55 #4809
by ewidance
Replied by ewidance on topic Re:Building a kernel
I'm also trying to build a kernel to solve my latency problems on Acer Travelmate 5720. I tried to on VESA graphics, and apply SMI issue modification. That did not solve my problems. So I tryed to build a custom kernel.
I've used the methodology detailled in www.lara.unb.br/~phsantana/data/files/te...HowTo_RTAI_Linux.pdf adapted to build on the latest RTAI patch.
Here's the adapted procedure for rtai-3.8.1, Kernel 2.6.32.20 :
Prerequisities :
su -
aptitude update && aptitude safe-upgrade
aptitude install \
kernel-package \
build-essential \
dh-make \
module-assistant \
ncurses-dev \
zlib1g-dev \
dh-kpatches \
fakeroot \
autoconf \
dctrl-tools
Download and decompress Kernel :
cd /usr/src
sudo wget ftp://kernel.org/pub/linux/kernel/v2.6/linux-2.6.32.20.tar.gz
sudo tar xzf linux-2.6.32.20.tar.gz
sudo mv linux-2.6.32.20 linux-2.6.32.20-rtai
sudo ln -s linux-2.6.32.20-rtai linux
Get RTAI from repository :
cd /usr/src
cvs -d:pserver:anonymous@cvs.gna.org:/cvs/rtai co vulcano
Kernel Patch over RTAI
cd linux
sudo patch -p1 < ../vulcano/base/arch/x86/patches/hal-linux-2.6.32.20-x86-2.7-03.patch
Get kernel config :
cd /usr/src/linux
cp /boot/config-`uname -r`./.config
Modifiy it:
sudo make xconfig
Kernel compilation
time make-kpkg clean
time make-kpkg --initrd --append-to-version -rtai --revision r1 kernel_image kernel_headers kernel_source
Wait for hours...
Kernel install
cd /usr/src
dpkg -i linux-image-2.6.32.20-rtai.deb
dpkg -i linux-headers-2.6.32.20-rtai.deb
Reboot over the new installled kernel.... and that hangs. It apperars the initrd is not built in the previous process... I have no idea about the reason why the ramdisk is not generated, since the "--initrd' option is on the make-kpkg command line. Any suggestion?
To work around, i generated ramdisk with the commande :
update-initramfs -u -v -t -k 2.6.32.20-rtai
It booted up.
RTAI compilation
cd /usr/src/vulcano
make xconfig
Default config should be ok for emc2.Save and quit. Next, do :
make
make install
reboot
RTAI tests :
cd /usr/realtime/testsuite/user/latency; ./run
cd /usr/realtime/testsuite/user/preempt; ./run
cd /usr/realtime/testsuite/user/switches; ./run
cd /usr/realtime/testsuite/kern/latency; ./run
cd /usr/realtime/testsuite/kern/preempt; ./run
cd /usr/realtime/testsuite/kern/switches; ./run
Unfortunately, RTAI tests were not ok. Any idea about improvement?
Prerequisities :
su -
aptitude install \
kernel-package \
build-essential \
dh-make \
module-assistant \
ncurses-dev \
zlib1g-dev \
dh-kpatches \
fakeroot \
autoconf \
dctrl-tools
cd /usr/src
cd /usr/src
cd linux
Get kernel config :
cd /usr/src/linux
Modifiy it:
sudo make xconfig
And apply the folowing modifications :
* Loadable module support —> Enable loadable module support —> enabled
* Loadable module support —> Module versioning support —> disabled
* Processor type and features —> Preemption Model —> Preemptible Kernel (Low-Latency Desktop)
* Processor type and features —> Interrupt pipeline —> enabled
* Processor type and features —> High Memory Support —> off
* Power management options (ACPI, APM) —> Legacy Power Management API —> disabled
* Power management options (ACPI, APM) —> Software Suspend —> disabled
* Power management options (ACPI, APM) —> ACPI (Advanced Configuration and Power Interface) Support—> ACPI Support —> disabled
* Power management options (ACPI, APM) —> APM (Advanced Power Management) BIOS Support —> APM BIOS Support —> disabled
* Power management options (ACPI, APM) —> CPU Frequency scaling —> CPU Frequency scaling —> disabled
* Power management options (ACPI, APM) —> Power Management support —> disabled
For non-SMP systems, disable symmetric multi-processing support;
* Processor type and features —> Symmetric multi-processing support —> disabled
Choose the most suitable processor family for your machine. For example, for a Pentium-III processor;
* Processor type and features —> Processor family —> Pentium-III / Celeron(Coppermine) / Pentium-III Xeon
If you have a dual cores CPU or SMP system, don’t choose a processor family which has no TSC (time stamp counter). This means that, for example, you can’t choose 586/K5/5x86/6x86/6x86MX as Processor family if you have a dual cores CPU. In con- clusion, choose the most suitable processor family for your machine.
Kernel compilation
Wait for hours...
Kernel install
cd /usr/src
It booted up.
RTAI compilation
cd /usr/src/vulcano
make xconfig
make
make install
reboot
RTAI tests :
Last edit: 23 Oct 2010 11:55 by ewidance.
24 Oct 2010 14:40 #4821
by pcnc1
I'm no kernel building pro but I have found this method helpful in the process. I'll use one thing I needed as an example but you can use whatever you like.
cd /usr/src/linux
Be vague:
$ grep -i ipipe .config
Get specific results:
CONFIG_IPIPE=n
Use it:
$ find -type f -name Makefile | xargs grep CONFIG_IPIPE
./arch/x86/kernel/Makefile:obj-$(CONFIG_IPIPE) += ipipe.o
Then in menuconfig use / to bring up the search, paste in CONFIG_IPIPE
See how to get there then navigate over and use the help feature to see if it is
what you are looking for, want etc.
I never did get make xconfig to work here. Menuconfig is a bit better so that might not be such a bad thing. I hope this helps you out some. It sure has helped me!
I still need to go through it all again one more time. I missed this gizmo called "evdev" or something, oh well! I need to be persistent.
cd /usr/src/linux
Be vague:
CONFIG_IPIPE=n
Use it:
Time to create page: 0.092 seconds
