You are using a simulated-realtime version of LinuxCNC, so testing
- gazlinux
28 Oct 2022 18:47 #255324
by gazlinux
You are using a simulated-realtime version of LinuxCNC, so testing was created by gazlinux
New user here and new to CNC just installed LinuxCNC on Ubuntu 22.10 and after connecting up USB to a chinese board to just confirm software to board handshake works, I get the error "You are using a simulated-realtime version of LinuxCNC, so testing / tuning hardware is unavailable."
[ ] create simulated hardware configuration box IS UNCHECKED.
Thanks for any pointers!
- arvidb
- Thank you received: 158
28 Oct 2022 19:48 #255329
by arvidb
Replied by arvidb on topic You are using a simulated-realtime version of LinuxCNC, so testing
1) LinuxCNC does not work over USB (it needs a low latency communication channel)
2) Probably a moot point because of 1), but: you need to install (and run) a real time kernel. Did you do that? What does 'uname -a' say?
- gazlinux
04 Nov 2022 15:29 #255921
by gazlinux
Replied by gazlinux on topic You are using a simulated-realtime version of LinuxCNC, so testing
Thank you for sharing that information.
My cheap amazon CNC came with an offline controller (linked below). The controller connects to the mainboard. Do you happen to know if I could swap out the offline controller and use that port on the mainboard to connect to connect to a LinuxPC (running real time kernel) serial port?
www.purewordstech.com/products/purewords...99960&pr_seq=uniform
05 Nov 2022 22:31 #256033
Replied by andypugh on topic You are using a simulated-realtime version of LinuxCNC, so testing
It's possible that your controller can be reflashed with the "Remora" firmware to make it work with LinuxCNC. (but if it connects with USB, then that can't work)
The linked page is not at all clear how the board communicates
The following user(s) said Thank You: arvidb
Time to create page: 0.365 seconds
