Trouble installing
08 Nov 2022 06:51 #256190 by An
Trouble installing was created by An
Hi linuxcnc, I’m trying to install this version www.linuxcnc.org/iso/linuxcnc-2.8.4-buster.iso of Debian and Linux onto a hp8200 and no matter what i try receive a ‘non system disk or disk error. No bootable device found’. I’ve tried just about every setting in bios and still no luck… has anyone run into this before? Should I just try a different install method?
thanks in advance for any help!
ant
08 Nov 2022 07:11 - 08 Nov 2022 07:19 #256191 by JPL
Replied by JPL on topic Trouble installing
Without any further details I would guess that it is because you're trying to install directly from the iso file... This will NOT work.
You will need to first 'flash' the iso file to a USB memory stick with an app such as Etcher that you can download here (free): www.balena.io/etcher/
Then you should be able to boot directly from the usb stick and proceed with the installation.
Last edit: 08 Nov 2022 07:19 by JPL.
08 Nov 2022 07:51 #256192 by An
Replied by An on topic Trouble installing
I sure was! I will give that a go. Thanks for the help.
Time to create page: 0.276 seconds
