Python issues on Bookworm
- mwc
- Thank you received: 10
03 Dec 2022 20:09 #258451
by mwc
Replied by mwc on topic Python issues on Bookworm
Is the toolpath display working?
From what I could work out from the error messages, the main issue seemed to stem from the OpenGL function not being found, and the error messages would be generated every time I did something that would trigger a change in the toolpath display (clicking a different view, zooming etc).
Installing XFCE didn't solve the problem for me.
- Maho-mill
05 Dec 2022 01:40 #258553
by Maho-mill
Replied by Maho-mill on topic Python issues on Bookworm
Confirmed, the toolpath display is not working. Getting errors like "HAL_Gremlin object has no attribute 'lathe_option'" and "...'logger'".
I went to Bookworm to try out a cheap MiniPC with an N5105 processor (UHD issues if not Bookworm), but latency is bad. Even doubling my watchdog timeout from my old PC I get MESA read errors. Returning MiniPC and going back to Buster for now.
- Thank you received: 4144
05 Dec 2022 03:32 - 05 Dec 2022 03:33 #258556
Replied by rodw on topic Python issues on Bookworm
If you need kernel > 4.9 for your hardware, I just tried this scripted installer with Bullseye
github.com/joco-nz/lcnc-bullseye-installer
just edit the script and add
If you don't it won't matter, you'll just need to install the .deb manually after the script is run
git clone https://github.com/LinuxCNC/linuxcnc.git ~/dev/linuxcnc/rip
git checkout 2.9 <--------------------------------- add this to checkout 2.9 branch
cd ~/dev/linuxcnc/rip/src/
./autogen.sh
./configure --with-realtime=uspace
Last edit: 05 Dec 2022 03:33 by rodw.
- Online
- Thank you received: 7466
09 Feb 2023 14:44 #264138
Replied by tommylight on topic Python issues on Bookworm
Spammer has left the building.
Time to create page: 0.198 seconds
