Need some help to .
30 Nov 2022 20:17 #258159 by orhan_izmir
Need some help to . was created by orhan_izmir
Hi.i bought computer but its install debian and we install 2.9.2linuxcnc but our mesa 7i49 not cominicate it.
i have got resolveresolve.can you sughest which computer i have to buy.
30 Nov 2022 22:37 #258164 by rodw
Replied by rodw on topic Need some help to .
normally the 7i49 would be connected to another Mesa card not to your PC.
We need more information about what you are trying to do.
30 Nov 2022 22:39 #258165 by PCW
Replied by PCW on topic Need some help to .
If you have a 7I49 (resolver interface) card you also need a 50 pin FPGA card to make the host PC interface, do you have this interface card?
(5I24,6I24,7I80HD, 7I93, 7I90HD etc are compatible 50 pin FPGA cards)
01 Dec 2022 04:35 #258183 by orhan_izmir
Replied by orhan_izmir on topic Need some help to .
İ done all systems with old computer. So i have a mesa 7i49, 7i37ta and 7i93..so we easly instal linuxcnc 2.9.2. 18 years old computer.than we did 3 axes machine without body and we stared the run .i saw the systems is super. We did nc file from nx cam.it was running.all of we did.than i decide the make computer new than i bought new computer .but new good one those not install 2.9.2.just 2.8 linux than we changed the Mother card new one .at the moment we install 2.9.2 but computer dont cominicate with 7i93
İn our sicuation is the resolver cards use to ne 2.9.2. Any way.can you suggest which Motherboard and orossesor i have to buy.
Br.
01 Dec 2022 05:18 #258185 by PCW
Inability to communicate with the 7I93 is most likely a network setup issue
and not likely anything to do with the computer hardware
What IP address is the 7I93 using and what does the command:
ip a
return on the current computer?
01 Dec 2022 05:27 #258188 by orhan_izmir
iwill sent
01 Dec 2022 09:29 #258196 by orhan_izmir
hi;first step is msi h410M-A pro motherboard and i3 10320 cpu,8gm hp ram m2 ssd 250 gb smsung harddisk.it was not boot linuxcnc we could do linuxmint than it was linuxcnc 2,8,2 but our 7i93 not connect it.
than ve changed the mother board its gygabyte B460M D2V model .we install the debian and linuxcnc 2,9 we did but at the moment our main card not cominicate 7i93.its mean on the card (7i93) there is green light but not lighing.
01 Dec 2022 10:21 #258197 by Aciera
Replied by Aciera on topic Need some help to .
ip a
Type this command in a terminal on the computer you are using to connect to the 7I93 and post the response you get.
ip a
Also, did you set an IP address on the 7I93?
01 Dec 2022 10:24 - 01 Dec 2022 10:27 #258198 by Aciera
If  translating to/from english maybe try:
www.deepl.com/translator
7I93 hangi IP adresini kullanıyor ve komut ne işe yarıyor:
ip a
mevcut bilgisayarda geri dönüş?
Last edit: 01 Dec 2022 10:27 by Aciera.
01 Dec 2022 11:53 #258204 by orhan_izmir
hi;
in old computer diffrent version when we are install we did on, on,,on.. but i will do again. my collig says like that .we will try monday night he is doing. i will be back.
Time to create page: 0.117 seconds
