Installing Linuxcnc from usb to ssd
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Dec 2022 13:33 #258350 by Aldenflorio
Installing Linuxcnc from usb to ssd was created by Aldenflorio
I’m having issues with the options and picking which ones to pick while installing, particularly partitioning. Would I be able to have someone help me with the options.
im open to a phone call if that would be easier
02 Dec 2022 13:43 #258353 by Todd Zuercher
Replied by Todd Zuercher on topic Installing Linuxcnc from usb to ssd
The simplest way and the one usually recommended for Linux novices is to simply install everything in a single partition (choose guided in the installation menu, and leave every thing as default.)
  • Aldenflorio
  • Platinum Member
  • Platinum Member
02 Dec 2022 13:44 - 02 Dec 2022 13:44 #258354 by Aldenflorio
Replied by Aldenflorio on topic Installing Linuxcnc from usb to ssd
  Okay what about this?
Last edit: 02 Dec 2022 13:44 by Aldenflorio.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
02 Dec 2022 14:05 #258358 by Aldenflorio
Would someone be willing to give me a call for a little to help me with this. I’m getting error messages and I am too afraid to mess things up.
id be willing to pay
02 Dec 2022 14:47 #258364 by Todd Zuercher
That may depend on your PC. Some computers BIOS (BIOS is technically the wrong term) have UEFI poorly implemented and give problems with using it. Personally I've not had a problem with it, but I've not installed Linux on many newer computers that support UEFI. The ones that I've tried worked without issue. Most older computers will require using BIOS or "Legacy Mode" (what some computers call the BIOS mode.) Which you should choose when installing will depend on your motherboard and its boot settings.
02 Dec 2022 23:35 #258396 by scotth
  • Aldenflorio
  • Platinum Member
  • Platinum Member
04 Dec 2022 14:23 #258525 by Aldenflorio
I’m getting this
04 Dec 2022 14:46 #258528 by tommylight
Replied by tommylight on topic Installing Linuxcnc from usb to ssd
Just a warning, press continue.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
04 Dec 2022 14:50 #258529 by Aldenflorio
  Okay when I hit continue I get this.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
04 Dec 2022 14:52 - 04 Dec 2022 14:53 #258530 by Aldenflorio
It’s hooked up via Ethernet
Last edit: 04 Dec 2022 14:53 by Aldenflorio.
Time to create page: 0.537 seconds
