Missing header file
08 Dec 2022 04:11 #258869 by ALANMTHOMASON
Missing header file was created by ALANMTHOMASON
Hello...
I am trying to build from source on a BeagleBone Black.  The configure process was successful.  But the make step is not sucessful.
After some time, I receive the following error:
rtapi/rtapi_io.h:39:12: fatal error: sys/io.h: No such file or directory
I can't find an io.h ...does anyone know where this should be?  The compiler directives in rtapi_io.h are looking for MODULE
#ifndef RTAPI_IO_H
#define RTAPI_IO_H
#define RTAPI_IO        // for disabling parts of header files
#include "config.h"        // build configuration
#include "rtapi.h"        // these functions
#ifdef MODULE
#  if LINUX_VERSION_CODE > KERNEL_VERSION(2,4,17)
#    include <asm/io.h>        /* inb(), outb() */
#  else
#    include <sys/io.h>        /* inb(), outb() */
#  endif
#else
#endif
#ifdef RTAPI_IO
Does anyone have any experience with this issue?
Thanks,  Alan
08 Dec 2022 23:56 #258938 by andypugh
Replied by andypugh on topic Missing header file
It seems that you need <asm-generic/io.h>
github.com/beagleboard/linux/blob/master...ude/asm-generic/io.h
It might be the case that inb() and outb() are not supported on the BBB.
rtapi is a shim layer to allow the same code to use several different realtime systems. it creates the functions rtapi_inb() and rtapi_outb() mapped to the appropriate functions on the platform:
linuxcnc.org/docs/2.9/html/man/man3/rtapi_inb.3rtapi.html
Time to create page: 0.164 seconds
