help needed compiling lcnc2.9 on kubuntu 20.04 for sim
- macsddau@linuxcnc
- Thank you received: 29
09 Dec 2022 12:04 #258993
by macsddau@linuxcnc
help needed compiling lcnc2.9 on kubuntu 20.04 for sim was created by macsddau@linuxcnc
Hi on my "science" pc runing Kubuntu 20.04, I try to update lcnc 2.9 sim with the last change of this branch.
I have update local copy of lcnc 2.9 git, add missing pakages, runand run command "./configure --with-realtime=uspace" according to the lcnc doc
linuxcnc.org/docs/devel/html/code/buildi...cnc.html#Quick-Start
Some month ago, I have already successfully build lcnc 2.9 (it is an update). But, this time, it doesn't work.
during the make, the following commandgive me this error (in french) :I'm not a programmer and I d'ont know what to do
How to solve this ?
"./autogen.sh"Some month ago, I have already successfully build lcnc 2.9 (it is an update). But, this time, it doesn't work.
a2x: deleting ~/Documents/linuxcnc/2.9/linuxcnc-dev-2.9~pre/docs/man/man1/halstreamer.1.xml Depending halstreamer.1make: *** Aucune règle pour fabriquer la cible « config.status », nécessaire pour « ../docs/man/man1/linuxcnc .1 ». Arrêt.How to solve this ?
- Thank you received: 7488
09 Dec 2022 19:33 - 09 Dec 2022 20:13 #259037
Replied by tommylight on topic help needed compiling lcnc2.9 on kubuntu 20.04 for sim
Try compiling without docs/documents.
./configure no-docs uspace
Last edit: 09 Dec 2022 20:13 by tommylight. Reason: more info
The following user(s) said Thank You: macsddau@linuxcnc
- JT
- Thank you received: 593
10 Dec 2022 12:51 #259089
by JT
Replied by JT on topic help needed compiling lcnc2.9 on kubuntu 20.04 for sim
You can use the help flag to see everything that can be done with configure.
john@cave:~/emc/src$ ./configure --help
`configure' configures LinuxCNC 2.9.0~pre1 to adapt to many kinds of systems.
Usage: ./configure [OPTION]... [VAR=VALUE]...
To assign environment variables (e.g., CC, CFLAGS...), specify them as
VAR=VALUE. See below for descriptions of some of the useful variables.
Defaults for the options are specified in brackets.
Configuration:
-h, --help display this help and exit
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
-q, --quiet, --silent do not print `checking ...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for `--cache-file=config.cache'
-n, --no-create do not create output files
--srcdir=DIR find the sources in DIR [configure dir or `..']
Installation directories:
--prefix=PREFIX install architecture-independent files in PREFIX
[run-in-place]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
[PREFIX]
By default, `make install' will install all the files in
`run-in-place/bin', `run-in-place/lib' etc. You can specify
an installation prefix other than `run-in-place' using `--prefix',
for instance `--prefix=$HOME'.
For better control, use the options below.
Fine tuning of the installation directories:
--bindir=DIR user executables [EPREFIX/bin]
--sbindir=DIR system admin executables [EPREFIX/sbin]
--libexecdir=DIR program executables [EPREFIX/libexec]
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
--sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
--localstatedir=DIR modifiable single-machine data [PREFIX/var]
--runstatedir=DIR modifiable per-process data [LOCALSTATEDIR/run]
--libdir=DIR object code libraries [EPREFIX/lib]
--includedir=DIR C header files [PREFIX/include]
--oldincludedir=DIR C header files for non-gcc [/usr/include]
--datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
--datadir=DIR read-only architecture-independent data [DATAROOTDIR]
--infodir=DIR info documentation [DATAROOTDIR/info]
--localedir=DIR locale-dependent data [DATAROOTDIR/locale]
--mandir=DIR man documentation [DATAROOTDIR/man]
--docdir=DIR documentation root [DATAROOTDIR/doc/linuxcnc]
--htmldir=DIR html documentation [DOCDIR]
--dvidir=DIR dvi documentation [DOCDIR]
--pdfdir=DIR pdf documentation [DOCDIR]
--psdir=DIR ps documentation [DOCDIR]
X features:
--x-includes=DIR X include files are in DIR
--x-libraries=DIR X library files are in DIR
System types:
--build=BUILD configure for building on BUILD [guessed]
--host=HOST cross-compile to build programs to run on HOST [BUILD]
Optional Features:
--disable-option-checking ignore unrecognized --enable/--with options
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--enable-non-distributable
To build LinuxCNC even if a license problem would
render the resulting binaries non-distributable
under the terms of the LinuxCNC license
--enable-simulator Deprecated! Use --with-realtime=uspace instead.
--enable-toolnml Use nml for tooldata, default is mmap
--disable-userspace-pci Disable userspace PCI access (use this if libudev is
unavailable).
--disable-gtk Disable the parts of LinuxCNC that depend on GTK.
--disable-gtk2 Disable the parts of LinuxCNC that depend on GTK2.
Ónly needed for classicladder)
--enable-build-documentation=FORMAT
Build documentation. FORMAT may be "Y" for both or
"pdf" or "html" if only one format is desired.
--disable-build-documentation-translation
Disable building documentation in languages other
than English.
--disable-check-runtime-deps
Skip checks for runtime requirements not needed
during the build process.
--disable-nls Don't use NLS.
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
--with-realtime=PATH Path where RTAI is installed, or "uspace" for POSIX
userspace.
--with-kernel-headers=PATH
Location for kernel headers.
--with-libmodbus Specify whether or not to build the drivers that use
libmodbus (defaults to "yes").
--with-libusb-1.0 Specify whether or not to build the drivers that use
libusb-1.0 (defaults to "yes").
--with-kbuild Specify if your kernel uses kbuild or not.
--with-module-dir=PATH Installation directory for kernel modules.
--with-rmmod=PATH Location of the rmmod program to use.
--with-insmod=PATH Location of the insmod program to use.
--with-boost[=ARG] use Boost library from a standard location
(ARG=yes), from the specified location (ARG=<path>),
or disable it (ARG=no) [ARG=yes]
--with-boost-libdir=LIB_DIR
Force given directory for boost libraries. Note that
this will override library path detection, so use
this parameter only if default library detection
fails and you know exactly where your boost
libraries are located.
--with-boost-python specify yes/no or the boost python library or suffix
to use
--with-tclConfig=PATH Specify the path to tclConfig.
--with-tkConfig=PATH Specify the path to tkConfig.
--with-x use the X Window System
--with-locale-dir=DIR Location of the locale file(s) [DATADIR/locale].
Some influential environment variables:
CXX C++ compiler command
CXXFLAGS C++ compiler flags
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CC C compiler command
CFLAGS C compiler flags
CPP C preprocessor
PYTHON_VERSION
The installed Python version to use, for example '2.3'. This
string will be appended to the Python interpreter canonical
name.
XMKMF Path to xmkmf, Makefile generator for X Window System
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
Report bugs to <emc-developers@lists.sourceforge.net>.
The following user(s) said Thank You: tommylight, macsddau@linuxcnc
- JT
10 Dec 2022 12:55 #259090
by JT
checking build system type... Invalid configuration `no-docs': machine `no-unknown' not recognized
configure: error: /bin/bash ./config.sub no-docs failedPlease Log in or Create an account to join the conversation.
10 Dec 2022 13:24 #259094
nodocs ?
Without -
Without -
- JT
10 Dec 2022 16:00 #259099
by JT
This did work however with 2.9
JT
./autogen.sh
./configure --enable-build-documentation=no
make
sudo make setuid
cd ..
. ./scripts/rip-environment
linuxcncJT
- JT
10 Dec 2022 16:23 #259104
by JT
This seems to work as well
JT
./configure --disable-build-documentationJT
- Thank you received: 4150
10 Dec 2022 22:07 - 10 Dec 2022 22:07 #259141
Replied by rodw on topic help needed compiling lcnc2.9 on kubuntu 20.04 for sim
This is a bug for sure. halstreamer is a part of linuxcnc so won't exist before its been built...
How can it be a dependency?
Should report as an issue on github.
But not buildng docs should fix it.
Last edit: 10 Dec 2022 22:07 by rodw.
- macsddau@linuxcnc
11 Dec 2022 16:48 #259198
Replied by macsddau@linuxcnc on topic help needed compiling lcnc2.9 on kubuntu 20.04 for sim
Sorry it was a mistake form me.
The last time I ran it, I don't check the result of .configure. Dependencies were not satisfied.
Since the prevouis build I have reinstall kubuntu and dependencies were missing.
Corrected...
The make successfull with the docs. I'm currently in the last step, running tests. New LCNC packages are allready installed.
Corrected...
- JT
17 Dec 2022 16:19 #259735
by JT
JT
There is a no-docs option for debian/configure but not for RIP configure. Just found that today when making a deb on Debian 11 which fails to build docs for some strange reason.nodocs ?
Without -
JT
Time to create page: 0.892 seconds
