- User Interfaces
- Other User Interfaces
- QtPyVCP
- Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
- cmw
- Thank you received: 7
11 Dec 2022 01:13 - 27 Dec 2022 06:01 #259172
by cmw
Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21 was created by cmw
I hope this helps someone interested in installing the LinuxCNC 2.10 and Probe Basic on MX 21. This process installs from a .deb and is not a RIP installation. LinuxCNC will show up in the Applications Menu of MX 21. I'm just a beginner at linux and this took me a few days to collect all the steps necessary from various resources but it now seems to work for now. Everything seems to change fast and keeping up a working installation process is a challenge. Installing MX 21 is easy. Just download and burn the latest live boot image to a USB drive using Rufus (in windows) or gnome-multi-writer in Linux. Once MX 21 real time kernal is installed, follow the attached file and it should get LinuxCNC and Probe Basic installed. I updated the attached file and I think it is correct now. Maybe someone can run thru it and check. One thing that I had to do since posting this the first time is downgrade Numpy to 1.23.5 to get editvcp to open without errors. Thanks
Last edit: 27 Dec 2022 06:01 by cmw.
The following user(s) said Thank You: tommylight, 0x2102, ChironFZ16, spumco
- spumco
- Thank you received: 882
19 Dec 2022 00:03 #259865
by spumco
Replied by spumco on topic Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
Thanks very much. If I could make an observation... I think you may have used a text editor to past the dependencies in the .doc file. A simple copy-paste of the .doc (or from the forum screen) in a terminal results in missing dependencies because the lines breaks & hyphenation don't carry over cleanly.
Had to past in to geany and remove all the extra line breaks.
An easier method, at least for newbie non-Linux folks like myself, is to paste all the dependencies in one line (in geany), then past them as 'code' in the forum editor. Them someone can grab & paste the whole thing with no confusing errors:
sudo apt install -y git debhelper dh-python libudev-dev tcl8.6-dev tk8.6-dev bwidget tclx libeditreadline-dev asciidoc dblatex docbook-xsl dvipng ghostscript graphviz groff imagemagick inkscape python3-lxml source-highlight w3c-linkchecker xsltproc texlive-extra-utils texlive-font-utils texlive-fonts-recommended texlive-lang-cyrillic texlive-lang-french texlive-lang-german texlive-lang-polish texlive-lang-spanish texlive-latex-recommended asciidoc-dblatex python3-dev python3-tk libxmu-dev libglu1-mesa-dev libgl1-mesa-dev libgtk2.0-dev libgtk-3-dev gettext intltool autoconf libboost-python-dev libmodbus-dev libusb-1.0-0-dev psmisc yapps2 libepoxy-dev python3-xlib python3-pyqt5 python3-dbus.mainloop.pyqt5 python3-pyqt5.qtopengl python3-pyqt5.qsci python3-pyqt5.qtmultimedia python3-pyqt5.qtquick qml-module-qtquick-controls gstreamer1.0-plugins-bad libqt5multimedia5-plugins pyqt5-dev-tools python3-dev python3-setuptools python3-wheel python3-pip python3-yapps dpkg-dev python3-serial libtk-img qttools5-dev qttools5-dev-tools python3-wheel espeak espeak-data espeak-ng freeglut3 gdal-data gstreamer1.0-tools libaec0 libarmadillo10 libarpack2 libcfitsio9 libcharls2 libdap27 libdapclient6v5 libespeak1 libfreexl1 libfyba0 libgdcm3.0 libgeos-c1v5 libgeotiff5 libgif7 libgtksourceview-3.0-dev libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libimagequant0 libkmlbase1 libkmldom1 libkmlengine1 liblept5 libmariadb3 libminizip1 libodbc1 libogdi4.1 libportaudio2 libpq5 libprotobuf23 libqhull8.0 librttopo1 libsocket++1 libspatialite7 libsuperlu5 libsz2 libtbb2 libtesseract4 liburiparser1 libxerces-c3.2 libxml2-dev mariadb-common mesa-utils mysql-common odbcinst odbcinst1debian2 proj-bin proj-data python3-configobj python3-espeak python3-gi-cairo python3-olefile python3-opencv python3-opengl python3-pil python3-pil.imagetk python3-pyqt5.qtsvg python3-pyqt5.qtwebkit tcl-tclreadline geotiff-bin gdal-bin glew-utils libgtksourceview-3.0-doc libhdf4-doc libhdf4-alt-dev hdf4-tools odbc-postgresql tdsodbc ogdi-bin python-configobj-doc libgle3 python-pil-doc python3-sqlalchemy python3-gst-1.0 texlive-lang-european build-essential:native
- Thank you received: 7417
19 Dec 2022 00:24 #259867
Replied by tommylight on topic Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
Thank you.
As a future reference, use only simple plain text editors for editing/copy/paste/etc, as Spumco mentioned, using anything else causes all kinds of issues.
- spumco
19 Dec 2022 00:34 - 19 Dec 2022 00:37 #259868
by spumco
Running through the rest of this, I'm getting a fail at:
./configure –with-realtime=uspace
edit - I think it needs two hyphens "--with..."
But still getting a fail.
Last edit: 19 Dec 2022 00:37 by spumco.
19 Dec 2022 00:37 - 19 Dec 2022 00:41 #259869
./configure -with-realtime=uspace
The first minus is not a minus sign, it is a bit longer.
Edit
Probably should be two of those minuses at the start:
./configure --with-realtime=uspace
Edit
Last edit: 19 Dec 2022 00:41 by tommylight. Reason: more info
- spumco
19 Dec 2022 00:44 #259870
by spumco
Yea, two hyphens needed, but still failing:
bash: ./configure: No such file or directory
19 Dec 2022 00:47 #259871
Yeah, probably not inside the correct folder.
From a quick glance of the document, i am sure i noticed some inconsistency with moving in and out of folders, but am to tired to sift through it.
Sorry.
Here is the procedure:
linuxcnc.org/docs/stable/html/code/building-linuxcnc.html
Sorry.
- spumco
19 Dec 2022 00:57 - 19 Dec 2022 01:02 #259872
by spumco
Thanks Tommy.
OP: I think you're missing some folder changes. Need to drop in to dev/linuxcnc/rip/src before the ./configure... command.
EDIT
Some other issues:
$ cd
###$ . ~/linuxcnc-dev/scripts/rip-environment
$ linuxcnc
Has some folder name problems. I think you need to run through your post start to finish and tidy up folder names and sequencing.
EDIT
Some other issues:
$ cd
$ linuxcnc
Last edit: 19 Dec 2022 01:02 by spumco.
- Thank you received: 4642
19 Dec 2022 23:32 #259911
If you follow the instructions on the web site to get a git clone then you will end up with the Linuxcnc source in ~/linuxcnc-dev/src
Is pretty much all I ever do. Several times an hour some days...
Replied by andypugh on topic Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
Only if that's where you have put it ....OP: I think you're missing some folder changes. Need to drop in to dev/linuxcnc/rip/src before the ./configure... command.
cd ~/linuxcnc-dev/src
./autogen.sh
./configure
make
sudo make setuid
- spumco
20 Dec 2022 03:31 #259925
by spumco
Yes... but I was trying to follow the OP's instructions verbatim to see if there were any hiccups. And there were.
cd ~/linuxcnc-dev/src ./autogen.sh ./configure make sudo make setuid Is pretty much all I ever do. Several times an hour some days...
Moderators: KCJ, Lcvette
- User Interfaces
- QtPyVCP
Time to create page: 0.157 seconds
