Installing LinuxCNC 2.10 And Probe Basic on Linux MX 21
12 May 2023 17:14 #271245 by Lcvette
2.10 is the development version of linuxcnc, you should be on 2.9 ( also technically a development version but more stable. both are run on debian 12 which is also currently the development version although it has a release date now to be current in a few weeks. debian 12 with the non free firmware is most likely every bit as compatible as mx21.
12 May 2023 17:21 #271246 by mattdom142
Ok, I can give that a try and see if it works.
do you expect that to work with probe basic as it is or will it take time for probe basic to be compatible with debian 12?
12 May 2023 18:31 #271248 by Lcvette
kcjengr.github.io/probe_basic/quick_start.html#
probe basic is now only compatible for install with debian 12 as a standard practice. use the link above for the correct installation.
12 May 2023 22:00 #271255 by JPL
Chris, Just wanted you to know that I was looking at your home page and saw that your link to QtPyVCP (qtpyvcp.kcjengr.com/) is leading to a 404 error. I think the correct link is www.qtpyvcp.com/
12 May 2023 22:16 #271256 by rodw
12 May 2023 22:30 - 12 May 2023 22:33 #271258 by JPL
I've checked again...
On the probe Basic homepage : kcjengr.github.io/probe_basic/index.html#
The first link to QtPyVCP is : h t t p ://qtpyvcp . kcjengr . com/ (nothing more than that but without the spaces)
Do you have something else???
Last edit: 12 May 2023 22:33 by JPL.
12 May 2023 22:35 #271260 by mattdom142
Which version of Debian did you go with?
MX21, Debian 11.7, Debian 12 or something else?
12 May 2023 22:46 #271263 by JPL
The first link worked for me
Rod, that is NOT the link I'm talking about. Yours is the first link after 'installation'. The one I'm talking about is when you click on QtPyVCP on the text on top of the page:   ProbeBasic is a QtPyVCP based user interface for the LinuxCNC machine control.
12 May 2023 22:48 #271264 by JPL
Not sure who you're asking but the installation page: kcjengr.github.io/probe_basic/quick_start.html clearly state that this is for Debian 12 (Bookworm)
13 May 2023 02:13 #271271 by Lcvette
Thanks i will get it corrected next time I'm at dev! Good looking out!
Chris
Moderators: KCJLcvette
Time to create page: 0.487 seconds
